Originally Posted by
screwtech02
Karl, drop your multi to 8, and push the fsb up to like 451-461, i am running 8gb of the Gskill/1000, and have mine set daily at the 5/6 divider, runnin the ram a bit over 1100, think its like 1108 or so, you wont need 1.6 for your proc either, or at least mine didnt, use 1.575/1.50, and 1.5 on cpu pll, try 1.55/57 on the norhtbridge, gtl settings at .60 cpu/.56 northbridge...
Hope this helps, also remember that the GTL volts should be amost 20% of whatever you have cpu/norhtbridge set to, or that is at least how i read into it...
