Thanks for your quick responce! To answer your question; I have version
2008.0122.1519.27310. How can I see performance when running something?
Man, push this QX6850. 8*400 is too low for this beast. And use ATI tool 0.27b3 to rise Vcore voltages. As I see you are on water, you can flash your card with Vmod bios 1.35v without problems. I use 1.35v Vmod bios and the temps are 53-55*C under load with 1007 GPU. Your sistem have big potential for performance.
Well as you can see I am a noobe, thanks for your help. Where do I find this ATI tool; Do I have it somewhere or do I have to download it. With regards to my mild overclock, man I just spent 5 grand on this pup and I have been chicken about overclocking. I am new at this and have been afraid to burn something up, just the CPU alone cost me 1000$. I guess I'll have to get up some courage and start experimenting.
Besides This Maximus board is a little buggie, it tends to overvolt, I have seen some guys on the Maximus thread fry their s**t.
Would anybody be able to do a test to see if the stable core speed is higher on a volt modded xt bios than a volt modded pro bios?
I always thought the pro bios was better because the memory benched faster. Is this not the case?
Forgot to plug in my Eheim 1250 pump today on my 2900s loop after trying out a 3870x2, it got hot one of the hose blew off one of the cards and got everything wet. I heard it when it happened and ran and unplugged it. It was in the process of rebooting when I jerked the chord from the power supply. I got everything apart and drying, been using a hair drier also. I will put it back together tomorrow and see what happens...
damn... u mean the water got so hot that the hose blew off?
then it must have been boiling hot. hope ur card is not dead.
get urself a 12v eheim pump, one thing less to care about when u fire up ur system ;)
Is there any way I can check the VRM temps without installing rivatuner? It's settings seem to conflict with those of both ATITool and CCC and I want to have a very hassle free software configuration here.
EDIT:
And you know what would be totally wicked .... a waterblock that fits the 2900 VRMs!!
What WBs do you have??
EDIT:
Looking at my VRMs under load, I see the temp of them varies greatly. For example the Slave #3 sits at 90C but the Slave 6 at 65C. Is this normal?
I got lucky, all hardware survived the water...
Iīm using the Innovatel Cool-Matic R600 waterblocks.
I guess itīs normal for the vrms to vary in temperature. some of them feed the gpu, which is very power hungry. not all parts on the card need that much power, so some of the vrms donīt get that hot.
Finnaly got my second 2900xt installed and running Crossfire. :banana: :banana: :banana: :banana:
I water cooled them both. see pic I posted on my signature.
today i wanted to watch a hd movie on my lcd tv thru the hdmi adapter of one of my cards. the movie looked great on my tv, but after a few seconds i thought to myself "damn.. is it silent movie or what??"
there is no audio signal coming out of my cards anymore. neither in winxp nor in win vista x64. iīve got all the latest drivers and hotfixes u need for hdmi audio in winxp, but itīs still dead silent. in win vista u donīt need any special drivers, theyīre already integrated, but there is also no sound on my tv when i choose the ati hd audio device.
what the heck is going on? i had hdmi audio working a few months ago. and now when i really wanna watch a hd movie itīs gone.
could it be because i flashed the card bios? i even tried a stock pro bios from the techpowerup site, but still no sound to hear.
i donīt know what to do else to get it working again.
can somebody help me please?
you need to set the playback to ati not your default sound card. its on the control panel under sound and audio devices. click the audio tab and select the ati device there.
Thank you for your compliment!
I must tell you though, I am realy dissapointed because between the additional GPU & Waterblock I spent around 664.00$, and did not get 664.00$ of additional performance. Before with a single card and while playing Crisis, I could set all video settings on high and ran flawlessly beautiful with the exeption of that if I set anty-alising past 2x it might stutter once in a while during hi action. Now with dual cards in crossfire I can go 8x and runs greate.
That is the only differance:cussing: Also 3DMark06 doesent see the additional card, and my score only went from 12283 to 12321. Both scores are with no overclocking.
Is there something I have to do with 3DMark06?
With ref. to what rad I am using? Good question! Because the first thing I noticed is that my CPU idle temps jumped from 36°c to 47°c after installing the second card.
Reason being is that for my Chassis, I bought a Gigabyte 3Dmercury with a cooling system incorporated in it. The problem is that while this case is a very nice well built case, it uses nothing more than a souped-up 3D Galaxy liquid cooling system with a little better rad but yet small.
Following are some pics:
http://i272.photobucket.com/albums/j...terPics019.jpg
http://i272.photobucket.com/albums/j...terPics021.jpg
Looks like I will have to piggie-back something like the following units on the side:
http://swiftech.com/products/MCR220-qp.asp
http://swiftech.com/products/MCB-120-r2.asp
I plan on assembling something like the following, without having to buy the whole kit:
http://swiftech.com/products/H20-220-APEX.asp
I will assemble this set up with dual 120mm fans. I suspect that my pump may not be able to handle all these extra components. Do you think that I might be able to incorporate a second pump in line with out causing to much aggitation and spillage out the resevuar vent? The problem is that my pump and res. looks like a one unit assy.
