Then... Bloody hell!
Hehe...gianni in action :D
Here are some really good dimms:
http://www.abload.de/thumb/2x512mb_geilonetccd_vz8.jpg
Yesterday I took off the HS now one of this dimms is dead :(
These are TCCD, do 245 @ 1.5-2-2-0 and 285 @ 2-3-3-0; but I could not took CL 2.5 and 3 with low voltage....for 200 mhz with 2.5-3-3-5 I need 3.03 volts !!!!!!!!!!!! :( I dont have any reason for this...
my gskill tccd had the same "problem". ;)
cl 2.5 and 3 was a no go, even at low or insane volts. they only worked with cl2
but luckily with 2-3-3-7 i got them to 275mhz. :D
very strange issue
Nice ram, shame one of them is dead. I'll try my G.skills tomorrow. Normally I bench on CH5, but it's fun to work with high freq's as well. Did 330mhz 2.5-4-3-7-1T spi1m once on those g.skills. No idea how that compares to 2-3-3-0 @ 285mhz, maybe you can tell.
I had a little fun with a 3500+ newcastle today. Didn't get the WR so I tried something else.
http://valid.x86-secret.com/show_oc.php?id=288523
272mhz:D the darn thing didn't want to run below 67mhz, instant freeze.
Oh, and S.I.H.;)
http://valid.x86-secret.com/show_oc.php?id=288531
And oldest K8 on the way, 0235.
200MHz on 3500+ :ROTF:
and one joke valid: http://valid.x86-secret.com/show_oc.php?id=283459
sorry for OT :rofl:
lol i can search:
http://valid.x86-secret.com/show_oc.php?id=194410
tccd loses normal cas2.5 and cas3 performance when given too much volts...save the high volts for bh-utt/5/ch-utt. it runs WAY tighter subtimings too.
That is my problem I cant run this sticks with 2.5 or 2.6 volts...
@ bruce
Dammned this was my record :D Which stepping ? You did some more mhz than my result.
I cant tell you the real differences between 330 @ 2.5-4-3-5 and 285 @ 2-3-3-0 because i cant test that yet. But i believe that it will aproximatelity the same.
Wow, that's a nice clock there on the winny.
I have a winny 3500+ which does 3116mhz on chilled water (2c) with 1.68vcore. I'll look out the stepping in a while, and post a cpuz verification for the hell of it :)
Not quite upto the standards of you guys but hey, we gotta try right? :p:
Thanks;) Your chip may be a nice one if it's not too coldbugged.
Max FSB on a 3500+ LBBLE 0515EPAW: http://valid.x86-secret.com/show_oc.php?id=289136 on air, 1.7v and 50c idle:D
And T.I.H: http://valid.x86-secret.com/show_oc.php?id=289136
Not too impressive, but almost no competition made it quite easy. Especially since I don't mind trying 1.9v on my chips, no matter what temps:D
That FX57 ES was quite nice (for an ES). http://valid.x86-secret.com/show_oc.php?id=289135
Not sure if it was coldbug or just the chip that maxed out there, no idea why I didn't try some other stuff.
you've posted the wrong linkt about your sempron.... correct: http://valid.x86-secret.com/show_oc.php?id=289134
i've prepared my openair-sys for today... but it's +5°C :(
Here's my 411MHz Sandy 3700MHz
http://valid.x86-secret.com/show_oc.php?id=288118 :up:
my openair session of today was not really successfully. :( outside temp 4°C, cooler temp 10°C.
http://valid.x86-secret.com/show_oc.php?id=289492
Pi-stable: 3387mhz@1.52v
setup:
http://octs.ripping.org/balkon-session.jpg
hope it gets colder, for your next try :)
I thought my Opty 154 was crappy, but I thought I should give it a try... And OMFGZZZZZ!!!!:D :D :D S.I.H.!
Opteron 154 wr, and Opteron overall WR, and s939 locked multi WR as well:
http://valid.x86-secret.com/show_oc.php?id=289541
This thing was so hot I had to use a pot (normally I use a heatsink with dice on it for B1 chips and other coldbugged stuff), but it worked nicely. -15c/1.824v. temps measured in ITE SmartGuradian, as the temp sensor crapped out at 2c.:shocked:
WTF!!!! congratz... you have to try with better cooling...
any superpi scores?
What the hell !!!! That opteron is amazing, bruce :eek:
Where did you get that opterom from ? Which stepping ?
@ Oj101
Nice HTT for an San Diego on the ATI chipset ;)
ok, i think when bruce uses dice he gets a bit better temps in norway than me here in the south :D
