i just got from newegg 165 CCB1E 0609 which is more than awesome
2.4Ghz @ 1.15V using stock cooling
also many reviews from users @ newegg statedd that they also got the 0609
http://www.newegg.com/Product/Produc...82E16819103588
Managed to get it stable, but had to up the VCOre .Problem here is the temp- I am going to mount a better pump and a larger water reservoir.
BTW, all that stepping hunt -never heard about it at Intel - some Intels that I had were better , some worse, but never in particular series.
Looks that maybe Intel has got a more consistent manufacturing process :p:
http://img214.imageshack.us/img214/2...ime30cj.th.jpg
my friend ordered from newegg like on thursday and he got the 0551 stepping which is not good. so i dont know about newegg.
Any info on the voltages needed for these?Quote:
Originally Posted by Rufus7
Just found out that the chip im getting has wafercharge of 1434904C60293. So can I take it this should be a good clocker as it has the '904' in it?Quote:
Yes Scoobie Dave that´s it. Nice clocks.
Kryolon that´s around 1,425 up to 1,55Vc.
Next Week i will know more.
Heres an Link to a OC List. Luftgekühlt=Aircooling
Wassergekühlt=Watercooling
http://www.forumdeluxx.de/forum/showthread.php?t=204404 Q
Hi guys, are there some memory or bios settings that are needed to get 2.9- 3ghz. Like async latency or something? I can't seem to get over 2.8ghz on any divider using tccd or bh'5 1gb kits. Taking the voltage up to 1.55 doesn't help either. My prime temps are 41-46'c depending on vcore so I don't think its heat. And I'm on water as well. Any input would be appreciated.
Damn..I want 165 like that too. :slobber:Quote:
Originally Posted by scoobie dave
Just donno where to get one. :(
i sell them all the time :p you gotta pay attentionQuote:
Originally Posted by mascot
Looking at the database there is an error. How can there be a 0632 week processor when we aren't even to the 32nd week of the year yet. That would be a processor made in July or August.
egh, i'll update that tomorrow
The guy I bought my new 0610 from told me the batch number is: 1434904C60777 so it sounds like I have a winner. It should be here in a few days, I can't wait.
Testing an Opty 165 CCB1E 0609FPMW I got from Monarch a couple of weeks ago...haven't tried higher yet
http://i55.photobucket.com/albums/g1...th_2700mhz.jpg
i updated the database. back up to 63 entries. lots of excellent OC's. i saw a couple of updates this weekend form users with avoid steppings that finally got their chips up to 2600-2700! :woot:
i fixed a bunch of typo's, i know the incorrect date is still there but i'm waiting on a reply from Grinch.
this weekend i finally got my 0615 up to 3006mhz on 1.475v. high temps caused core 0 to fail though. i need some h2o and a dfi. :stick:
My stepping is:Quote:
Originally Posted by Burky
CCBBE 0610DPMW
1434904C60293
I cant wait too! :banana:
Should arrive this week from the States. :woot:
so outta the long line which is hte batch number?
and which are hte good batch numbers?
For the database... How many hours of prime is considered as prime stable?
http://img401.imageshack.us/img401/5...61391df.th.jpg
Have you sent a PM?Quote:
Originally Posted by alpha0ne
I dont understand why my entry that was listed was taken out, I then posted a screenshot with all relevent information again and still no listing ????Quote:
Originally Posted by itznfb
@alpha0ne your information would have been deleted if it deviated from this format:
Model: 165
Stepping: CCBBE
Date: 0615
Package Code: EPMW
CPU Frequency: 2900
VCore: 1.45
Cooling: TT Big Typhoon
Load Temperature: 45c
Prime Stability: Prime Stable
send me a PM with your info in that format and i'll repost it
See the quote :p:Quote:
Originally Posted by ChkDsk
Done thanksQuote:
http://i16.photobucket.com/albums/b2...e/3f0354c3.jpg
well, considering i only test for 30 minutes, i would consider anything over 30 min to be prime stable. these are OC boxes, not mission critical DB servers :p:Quote:
Update: just received a CCB1E 0609FPMW from monarch, it shipped Friday.
The stepping CCBBE 0615EPMW is not to bad.
I could run prime for 53 min before it stopped. With some tweaking I belive it could get stable for much longer.
http://home.no/erikkjos/3GHz%2053min.JPG
How long did it last? That's still awesome for a bad motherboard and high temps :eek: Can't wait to play with mine :cheers:Quote:
