Oh,did not see,guess it's in normal range then :)
hmm, so PSC still better??? :(
No,an air very good psc comes close to very good samsungs,but the thing is psc scales with cold and you can get awesome results.However nowdays you can't find any good bbse or psc in retail,so good samsung are the only choice....
Your score is not too bad, 6min22.1 without cw translates into ~6min19.0 with CW, which is about on par with other Samsung scores in this thread. Note that all the top Samsung times are done in 4x4Gb configs, which is said to be at least 1 second faster.
If you're on air, then it's a lot easier to get a good time (sub 6min20) with Samsungs than PSC. You don't need to have super duper PSC kits to do 1300+ CL6 / CL7-tWCL7 on LN2, properly tweaked average stuff should be able to do it too.
BTW, you can no longer find good Samsungs in retail as well ;)
Here's something I've been working on last week. Also no CW and timings not minimised as the board started acting funny after this run.
http://www.abload.de/img/1360c6_192v_32m_ln2l2um6.png
That trrsr is huge,setting it 5 will shave 1 sec+....But very good trcd
Thanks a lot Sam! I just planned to try with 4 sticks, I have them. I hope that my CPU can kkep them 4x4 at 1380+ MHz .
About my score, I thought that it was slower than seems to be. Will try to improve it a little bit trying more OSes too.
SOmebody noticed that on Asrock Z77 OC Formula (or other Z77 too) the 2800 divider is slower than 2666/2600?
Thanks for the help!
Whats ur aida delex ?
TaPaKaH your result with PSC or BBSE?
this are my 24/7 settings i think its a nice SPI32 for it :) using 2x4GB TridentX 2666CL10
http://i.imgur.com/9YFVj.jpg
http://i.imgur.com/dYwXv.jpg
u may notice that vcore is high for 5GHz thats cause im using OFFSET and EXTREME LLC as games love it, if i dont use it games crash
^^Andre^^ it is nice that you are keeping these thread alive with your gSkills 2666 results. I will try to match what you have done if possible with my 2666 CL10. :up:
Cool, give them 1.75v and LB 1 :p
Nice 24/7 settings btw xD
I got 12min with my G620 and psc lol
Here we go!
ASRock Z77 Oc Formula
Corsair Dominator Platinum 2666C10
http://img211.imageshack.us/img211/3...aphsot0022.jpg
SHould be faster with 16 GB? I think that it's still a bit slow
Yea,if you run 16GB you will gain at least 1 second :) compared to 8 gb,so you still have some time to catch...
I gain only about 0.5 switching from 8 to 16 gb...don't know where i'm doing wrong! Tried 4 OS too...
Don't know mate,my best run at 2800 9-12-12 was 18.250,at 2860 i had the same but on a different os and not a good run...
Delex, have you tested tCWL 7? I find 7 is generally quicker unless pushing extra volts then 6 sometimes surprises me... also 6 may be the reason 2800 is slower for you.
I think I remember Splave mentioning he found some OCF dividers faster than others in the 3D01 low clock thread.
That is right 100:133 strap is better at efficiency in 2001, i did not find it better in spi though....
Allen imo the fastest ever config on Ivy is Cas7 twcl 6
I can't get tWCL6 to work at 1300+MHz with any CAS on my PSC (LN2) so I run whatever I can :)
Here is mine:
http://img856.imageshack.us/img856/9504/spi32mlcc.jpg
Needs improvements though :)
Question: Is it efficient based on the timmings I used?
