i like your chieftec also fredz77,looks good,seems like everyone has a really nice pc
I disagree, too big is when you have to move your head or even your body just to see another part of the screen... Its called diminishing return. IMO anything over 30 is too big under 3 feet away, if your 4 feet away you can go 30+
Its a Drobo, if you go to my flickr page you can see everything listed piece by piece.
Tile, I love the acrylic work on the side panel.
Moved my desk to my bedroom. However kept the PC in another room. Having a powerful system w/o the heat dump or the loud fans in the same room = bliss.
http://i18.photobucket.com/albums/b1...e/IMG_2510.jpg
http://i18.photobucket.com/albums/b1...e/IMG_2508.jpg
Ahh, tidy room, tidy table, tidy audio setup .. and all spoiled by ugly wires near wall :(
Can't make cables disappear. I did by best cable management I could. http://smiliesftw.com/x/dunno.gif
My Test Bench # 1 (yup, there's a # 2 :p:) :
http://i1021.photobucket.com/albums/...nchRevD-01.jpg
http://i1021.photobucket.com/albums/...nchRevD-02.jpg
http://i1021.photobucket.com/albums/...nchRevD-03.jpg
http://i1021.photobucket.com/albums/...nchRevD-06.jpg
http://i1021.photobucket.com/albums/...nchRevD-05.jpg
http://i1021.photobucket.com/albums/...nchRevD-04.jpg
http://img.photobucket.com/albums/v6...lessNKROCh.jpg
http://i1021.photobucket.com/albums/...nchRevD-07.jpg
http://i1021.photobucket.com/albums/...Bench1-WEI.jpg
Specs :
Mobo : ASRock 890FX Deluxe3 (AMD 890FX / ATX)
CPU : AMD Phenom II X6 1055T 2.8GHz w/ EK Supreme Acetal waterblock
Memory : 2 x 2GB Corsair Dorminator DDR3-1600 (stock timing : 8-8-8-24)
SSD : Intel X-25M G2 80GB (Firmware : 02HD w/ TRIM)
HDD : WD Caviar Green 1TB
Gfx Card : Sapphire Vapor-X HD5770 1 GB
Monitor : Dell 2407WFP 24-inch
Audio Card : On-board
Speakers : Bose Companion 2 Series II
Power Supply : Antec Signature 650W (Modular / 80PLUS Bronze-certified)
Fan : Intake - Scythe Kaze Maru 140mm 1200rpm
Keyboard : Filco Majestouch Tenkeyless FBKN87M/EB with N-Key Rollover (Cherry MX Brown keyswitch)
Mouse : Razor Diamondback (Plasma Blue)
Water Cooling Parts :
CPU Waterblock : EK Supreme Acetal
Pump : Swiftech MCP350 with XSPC Res Top
Radiator : Swiftech MCR120-QP
Fan : Panaflo FBA12G12L1A (120mm / 1700 rpm)
Tubing : PrimoFlex Pro LRT 3/8in. ID 1/2in. OD (Clear)
Coolant : Fluid XP+ ECO-EARTH (Clear)
IDLE POWER CONSUMPTION (excluding monitor and speakers) : 121 W
MONITOR POWER CONSUMPTION : 50 W
My HTPC until I can find a Luxa2 LM300 case for it.
http://i18.photobucket.com/albums/b1...e/IMG_2514.jpg
You got a 850-1050w psu for your htcp?
lol, reminds me of..
http://i8.photobucket.com/albums/a1/...c/1kw-htpc.jpg
elpibe10: Nice set up, but what is your real Windows 7 scores? :cool:
@Helix: Really nice cable management, and cool part too :D
Built this rig for my eldest son's girlfriend :
http://i1021.photobucket.com/albums/...anberryRed.jpg
Abee acubic T20 Cranberry Red Mini ITX case (Made in Japan)
http://i1021.photobucket.com/albums/...rior2-RevA.jpg
http://i1021.photobucket.com/albums/...block-RevA.jpg
http://i1021.photobucket.com/albums/...terblock-R.jpg
http://i1021.photobucket.com/albums/...rior1-RevA.jpg
http://i1021.photobucket.com/albums/...aptor300GB.jpg
Specs :
Mobo : ECS H55H-I (Intel H55 / Mini ITX)
CPU : Intel Core i5-650 3.2GHz w/ EK Supreme LT Acetal waterblock
Memory : 2 x 2GB Kingston ValueRAM DDR3-1333 CL9
HDD : WD VelociRaptor 300GB
Gfx Card : XFX HD5750 1GB w/ EK-NB/SB 5 Acetal waterblock
Monitor : Samsung XL2370 LED 23-inch widescreen
Power Supply : Seasonic S12-II 380W (80PLUS-certified)
Fans : Intake - Noctua NF-S12B FLX 120mm 1200rpm / Exhaust : Noctua NF-P12-1300 120mm 1300rpm (undervolted to 1100rpm)
Keyboard : Enermax Aurora Micro (Black)
Mouse : Razer Krait (Atomic Red)
CPU Waterblock : EK Supreme LT Acetal
Gfx Card Waterblock : EK-NB/SB 5 Acetal
Pump : D-Tek DB-1
Radiator : XSPC RS120
Reservoir : Swiftech MCRES-MICRO
Tubing : Tygon B-44-4X 3/8in. ID 1/2in. OD (Clear)
Coolant : Alphacool Cape Kelvin Catcher CKC (Clear)
IDLE POWER CONSUMPTION (excl. monitor & speakers) : 66W
RUNNING FURMARK (excl. monitor & speakers) : 160W
HelixPC => Awesome :eek:
