Hey Dede,
Just for clarification what exactly did the Vcore Drop=Disabled helped you achieve?
K Linflas no worries, I have to get away for 10 days (Wed 16th till Mon 28th) and I won't be able to play with my Xmas toy as much as I wanted . My first board was RMA so I got little time to get it to run 450x9 till then.
What is your high temp peak on the cpu core with those settings? Did you lapp you Q6600?
I'll better show you :)
this is after I disable the VCore Droop Control
http://img261.imageshack.us/img261/9...9-VCore.th.png
and this is enabled
http://img89.imageshack.us/img89/922...6-VCore.th.png
hope this helps
I'm using your setting's Praz anyways but this is just better setting for 24/7 use since my idle voltage is lower with Vcore droop OFF, but for higher OC I don't know yet, but will find out soon as I'm going to benchmark on my new board so hope I'm going over 4GHz with my Quad :D.
But I think the droop control is just doing good job so I'll leave it OFF for now until I know better :)
This is what I got so far, but for some reason I can't finish 24hrs OCCT (beta) it it reboots the PC in some point:
http://i18.tinypic.com/72av71c.png
have you tried slightly more CPU / VTT / NB CORE?
Yes and it doesn't seam to respond well I guess my CPU temp gets too high (72oC peak on Smartguardian) and it's probably due to a bad Apogee GT contact with it. I will try to sort this out when I come back from vacations by the end of the month.
I can play games and run a lot of 3d tests but when it comes to OCCT 12-24hrs it just reboots :-(
nice going there Joreibr, why you need to stress test it for 24 hour's ? I would never do this except you really do extreme stuff on your computer like video editing or 3D animations
maybe you also need to change the GTL a few 'points' , like these people http://edgeofstability.com/articles/.../gtl/gtl7.html went from 108/110 to 112/112 and they fixed their prime stability problem...
i realy hope my x38 turns up tomorrow, im getting desperate :hump:
teasing me with those 4Ghz screen shots too ;) :D
That is the issue, it is vista only problem
I just got the night off! lol, so will get those settings up tonight
Cooling is D-tek fusion, no mods, no nozzles or bowing, with 1/2" tubing on a PA 120.3 and D5 pump. Cpu is not lapped.
I hear ya, a year on 680i made me a jealous guy also, but now I am a have, not a have not
3DMark01, obviously I have no idea how to set this one up, never used it before, so compared to your score, I did something wrong, not worth my time to figure it out, as I don't play benchmarks.
http://img265.imageshack.us/img265/2133/3d01se7.gif
anyone wanting to buy my DFI X38 (USA), PM me!
OCCT Stuff and bios settings, BTW huge props to Praz for the memory timings on the GSkill 2x2GB PC2-8000 Kit I have, SuperPi 32M stable, so all is good, thanks Praz!
http://img239.imageshack.us/img239/5...tstableyj5.gif
http://byfiles.storage.live.com/y1pD...tY3y4TgR-v9N30
http://byfiles.storage.live.com/y1pD...l_UKvmzqPxgtMA
http://byfiles.storage.live.com/y1pD...Ddyx89ntc479aM
http://byfiles.storage.live.com/y1pD...j3X2Vw7TfmlCCI
Code:CPU Feature Page
Thermal Management Control................Disabled
PPM (EIST) Mode...........................Disabled
Limit CPUID MaxVal........................Disabled
CIE Function..............................Auto
Execute Disable Bit.......................Enabled
Virtualization Technology.................Enabled
Core Multi-Processing.....................Enabled
Main BIOS Page
Exist Setup Shutdown......................Mode 1
Shutdown After AC Loss....................Enabled
O. C. Fail Retry Counter..................0
CLOCK VC0 Divider.........................Auto
CPU Clock Ratio...........................9x
CPU Clock.................................445 MHz
Boot Up Clock.............................Auto
DRAM Speed................................333/800
PCIE Clock................................110 MHz
PCIE Slot Config..........................1X 1X
CPU Spread Spectrum.......................Disabled
PCIE Spread Spectrum......................Disabled
SATA Spread Spectrum......................Disabled
Voltage Setting Page
CPU VID Control...........................1.4875V
CPU VID Special Add.......................Auto
DRAM Voltage Control......................2.100V
SB Core/CPU PLL Voltage...................1.760V
NB Core Voltage...........................1.543V
CPU VTT Voltage...........................1.366V
VCore Droop Control.......................Enabled
Clockgen Voltage Control..................3.60V
GTL+ Buffers Strength.....................Strong
Host Slew Rate............................Weak
GTL REF Voltage Control...................Disabled
CPU GTL1/3 REF Volt.......................N/A
CPU GTL 0/2 REF Volt......................N/A
North Bridge GTL REF Volt ................N/A
DRAM Timing Page
Enhance Data Transmitting.................Fast
Enhance Addressing........................Fast
T2 Dispatch...............................Enabled
Clock Setting Fine Delay..................Listed Below
CAS Latency Time (tCL)....................5
RAS# to CAS# Delay (tRCD).................5
RAS# Precharge (tRP)......................3
Precharge Delay (tRAS)....................15
All Precharge to Act......................4
REF to ACT Delay (tRFC)...................52
Performance Level.........................8
Read Delay Phase Adjust...................Listed Below
MCH ODT Latency...........................2
Write to PRE Delay (tWR)..................14
Rank Write to Read (tWTR).................11
ACT to ACT Delay (tRRD)...................3
Read to Write Delay (tRDWR)...............8
Ranks Write to Write (tWRWR)..............4
Ranks Read to Read (tRDRD)................5
Ranks Write to Read (tWRRD)...............4
Read CAS# Precharge (tRTP)................3
ALL PRE to Refresh........................4
Read Delay Phase Adjust Page
Channel 1 Phase 0 Pull-In.................Enabled
Channel 1 Phase 1 Pull-In.................Enabled
Channel 1 Phase 2 Pull-In.................Enabled
Channel 1 Phase 3 Pull-In.................Enabled
Channel 1 Phase 4 Pull-In.................Enabled
Channel 2 Phase 0 Pull-In.................Enabled
Channel 2 Phase 1 Pull-In.................Auto
Channel 2 Phase 2 Pull-In.................Enabled
Channel 2 Phase 3 Pull-In.................Enabled
Channel 2 Phase 4 Pull-In.................Enabled
Clock Setting Fine Delay Page
Ch1 Clock Crossing Setting................More Aggressive
DIMM 1 Clock fine delay...................Current 89ps
DIMM 2 Clock fine delay...................Current 456ps
DIMM 1 Control fine delay.................Current 534ps
DIMM 2 Control fine delay.................Current 289ps
Ch 1 Command fine delay...................Current 801ps
Ch2 Clock Crossing Setting................More Aggressive
DIMM 3 Clock fine delay...................Current 89ps
DIMM 4 Clock fine delay...................Current 400ps
DIMM 3 Control fine delay.................Current 367ps
DIMM 4 Control fine delay.................Current 356ps
Ch 2 Command fine delay...................Current 801ps
Ch1Ch2 CommonClock Setting................More Aggressive
Ch1 RDCAS GNT-Chip Delay..................Auto
Ch1 WRCAS GNT-Chip Delay..................Auto
Ch1 Command to CS Delay...................Auto
Ch2 RDCAS GNT-Chip Delay..................Auto
Ch2 WRCAS GNT-Chip Delay..................Auto
Ch2 Command to CS Delay...................Auto
Thanks for the settings Linflas I will try to get there.
But I noticed I don't have this setting:
"Execute Disable Bit.......................Enabled" :shrug:
EDIT: I did a clear cmos and the value appeared again. Go figures.
My Bios is the latest Beta to correct NB volts...
i replied to your PM
http://www.anandtech.com/printarticle.aspx?i=3129 says that:
counterintuitive, indeed.... maybe it should be better named 'vcore droop allow' than 'control' , by some miracle of engineering they have made the board inherently droop-proof ,and they have to artificially re-introduce the vdroop just to be safe, perhaps...Quote:
VCore Droop Control: Set this function to DISABLED for overclocking; counter-intuitively, the ENABLED setting causes the CPU core voltage to sag when the CPU is placed under load.
Dunno, Intel spec ask for this vdroop on thier chip, it is probably a safety measure, don't know the tech side of it, better safe then sorry, keep it enabled.
well, more fun, Vista64, Aero enabled 3870's 860/1200, no tweaks, 68 background process. LOL!
http://img81.imageshack.us/img81/4793/3d06fu7.gif
http://service.futuremark.com/compare?3dm06=4693257
wow i need a quad and a second 3870
okay since this is not just an overclocking thread but also a discussion thread among other things... what do you think are the prospects of using a geforce card in an x38 board... SLI is a remote possibility, i've heard that you need to modify the bios to do it, or maybe even just the drivers ... or can something other than a graphics card use the x16 lane, such as a high powered PPU coming out in the near future?
