so i guess its typical of the vrms to get this hot... :shakes:
What kind of cooling do you have?
I'm pretty sure they are not going to last long at those temps. That 1950Pro was pretty extreme example, in vr-zone review they get 114C and over 120C when overclocking.
If anyone could tell us what are max temps for those VRM's?
In standard cooler I get 72C max temps for vrm's. Some might say even thats too much but I think about 85C would be safe.
One topic I found -look at those temps! Over 120C.
2900 PRO-XT Mod. Full air stock cooler test. Q6600 3950 Mhz air cooler.
3DMARK2006 SINGLE 930 / 981 Mhz : 15207
3DMARK2006 CF 930 / 998 Mhz :21045
3DMARK2003 CF 904 / 994 Mhz :75865
@EXPANDER, very nice clock on air. If you put under water with Vmod bios...
ok so the sinks i have for my vrm's had the worst thermal tape ever on them so i stuck them on with double sided tape *regular stuff.. thin though* i watched the vrm's touch 100 after 18min of running atitool scrubbing for artifacts *reported in rivatuner*
i thought it was way too hot and my tape was the cause so i put the stock cooler back on *well the plate anyways... gotta have the gpu's under liquid* and watched the vrms get up to 118 after the same amount of time! wtf!??! DOUBLE SIDED STUPID TAPE IS BETTER THAN STOCK COOLING! :rofl:
one thing i did play with is just cooling the black part of the stock plate with compressed air... not much either and i watched my temps DROP. so i think im in need of some good cooling on both sides:rolleyes:
Have a look at how i solved it (post #1027)
http://www.xtremesystems.org/forums/...postcount=1027
The mosfets are perfectly lined up to each other, no need for a thermal pad between chip and heatsink, just AS Ceramique.
[QUOTE=ZenEffect;2778808]ALSO
ive found that they hynx 1.1 memory bios version is more stable. used to crash all the time now no crash at all... i thought 2900pro's were supposed to have hynx 1.0's but i guess i got 1.1's so if you have flashed from a pro to xt, and are on 1.0 try the 1.1's to get a bit higher memory clock. im running the mem at 990 with stock voltages.[QUOTE]
thanks for that one ZenEffect.
i couldnīt get my mem one mhz above 900 without heavy artifacting in 3dmark06. i didnīt really know that there are cards with different ram chips. i just used a sapphire bios that i found on techpowerup at that time (a week or so after the release of the 2900pro).
i downloaded the hynix1.1 bios and now i can up my mem without any artifacts.
i even tried 999 on the mem, without artifacting, but 3dmark just locks up. guess iīll need a little more volts for the mem then.
edit: lol.. why does that "quote" thing not work???
Is there a Hynx 1.1 bios for the 1gb gddr4 2900pro?
On the xt card I can not get it to run more than 940/970 no mater what volts and it takes 1.35 to do that. The pro card flashed to xt it ran at 985/1071 as a single with 1.35. When I put it in crossfire I had to back it down to 960/1060 I think it was or it would freeze in 3DMark06...
Hmm.... thats interesting. I have a question. Does your XT flashed pro get the same core overclock with a volt modded pro bios?
Also, I just recieved the d-tek unisink r600 version, and I have a question. It comes with a thin aluminum heatspreader (no fins or anything) for the memory on the back of the card. But on the back I already have the ramsinks that came with the thermalright hr-03, there are three of those sinks in total, one for each row of ram chips. They are also aluminum but have nice flared fins, unlike the d-tek aluminum heatspreader. Should I keep the thermalright ramsinks, or use the d-tek heatspreader?
seems my video cards like 1.30 volts better than 1.35 :shrug:
1.30 let me clock higher than 1.35
I am not sure, I did not try it. I just flashed it to a xt and then started messing with it and ended up taking a card out and checking each one individually and running 3DMark06 until it failed and back off the clocks a little bit. I remember my first xt I could clock to 910/1070 with atitool but I RMA it and got a not so good of card evidently. The pro card ran higher than what I have it right now by itself but would not do those clocks when put back in crossfire...
Last night I ordered my 2nd 2900xt 1Gb GDDR4, along with a Koolance VID-290 water block for it too.
Come on Crossfire! :banana: :banana: :banana: :banana:
Should all be in by Wednesday, I'll update pic posting after I assemble Thursday.
Hope you, or someone can help me!
Right now with my mild overclock and just one card I get the following score; I know they are bad, hope this will change when my second GPU arrives wednesday:
http://i272.photobucket.com/albums/j...verclocked.jpg
What do you suggest?
Also, On my catalist control center, under overclocking; I have unlocked and set to 743Mhz on GPU clock, and 1000Mhz on memory clock, but current clock settings read low Why? see following:
http://i272.photobucket.com/albums/j...trolCenter.jpg
Is this because I am not runing something now or what? also how can I monitor this while playing a game or something that demands performance.
Please advise! thank you in advance
