Just like my old DFI nF3-250Gb and Abit NF7 before it. :toast:Quote:
I forgot to disable some bios options but not bad coming from the DFI Infinity:
http://img.photobucket.com/albums/v7..._091706_02.jpg
Originally Posted by ccl2006
that ocz plat has alot more room in it. and so does the FSB crank it up man...
well we need to know what cpu, ram, etc...
Originally Posted by eXceededgoku
uhm who are you addressing that to ?
LOL im not actually sure, since the post I was referring to had/s disappeared :S.... perhaps wrong forum :)
New Bios We Need More Bios's!!!
Join the club, a week now since the last bios update.
Their ears still burning . Creative tons of Xfi RMA complaints !!!
Fix the vcore problem!! with new E6600 1.55v on bios it semms 1.50v in everest Dq6 good board..:D
[img]http://img70.imageshack.us/img70/2307/15vlargejy9.jpg[img]
Originally Posted by palum
hahaha
thats why i have never had a need to go beyond my Audigy 2 Plat.
digital out.. 7.1,... yada yada.. and it DEFINATELY doesnt have the issue i see poeple have with the X-Fi
Originally Posted by fenomenhaa
1.5v w/ 3.8v
wow.. best i have seen yet.. seems... a bit low for 3.8ghz
what chip is that ? week 26? 27?
L628AxxxQuote:
Originally Posted by Lestat
This is really pissing me off that I can't use Qflash with a USB floppy drive. Not to mention @Flash keeps crashing in windows, sheesh.
you can use it with a usb floppy dude but ONLY if your floppy seen as a floppy by the bios.
some usb floppies dont like it. mine works fine on my mobo
you can also use a thumb drive.
get off your butt and just go buy a floppy
and never use the stupid windows flashers.
and lastly.. but not least... use your damn floppy and make a startup disk and flash it via dos. end of story.
be mad all you want but be mad at yourself for missing the most obvious of flash methods.... D O S . . . .
sorry man i didnt mean to sound like a d|ck just people who ditch their floppies need to get with the program,, floppies are years from being done for.....
for me @flash only crashed once in Vista... but flashed 8 times in XP and no problems so far, not a single crashQuote:
Originally Posted by darkandlong
Edit:
Nevermind, figured it out. Need to enable boot from USB-FDD from the boot order for the board to check for the floppy. Flashed to F5 with no issues.
I tried F5C and it was crappy even at stock speeds as it would make my system hang while loading the apps at windows. i reverted back to bios F3 and its rock stable. i wonder what's in F5C that makes it problematic. ;)
ouch, with this bios i could get 440x8 which i could previosuly not. Did you reset the cmos? On the other hand i do have the xfi issues.Quote:
yup i did try to reset cmos thrice but the problems in windows were still there. i am going to use F4 again later and see how it fares against the F3 and F5c.Quote:
Originally Posted by FirePhoenixCtk
just like to check with you all...anyone has any issues or sucess in using sata optical drives with ds4 either on the gigabyte or intel sata controller?
Will you guys be kind enough to post here the most ideal memory settings for Gigabyte 965 mobos which will make our OC more stable? Thanks in advance!
currently running geil ddr880 4-4-4-12 @ 2.1vQuote:
wtf , i was about to get some dry ice, but this DQ6 is no go if you put 1.59v Vcore or more? :confused:
make sure eist and tm2 and all that related stuff is disabled if you oc, i have seen many people puch well into the 1.65v region on DQ6s the problem is with all the above turned on the board will volt down the chip to like 1.2 and if you try to hit some mad OC with 1.2v your going to fail :)
