If you haven't found it by now...try here.
@CrazyNutz: To add to your conspiracy theory, have you ever wonder why there are only voltage sensors for Vcore and the 3 main rails on this board? Is Asus simply being cheap or...? ;)
Is it worth flashing from 1004 to 1013?
Well I have no bugs that I am aware of, everything "seems" to be ok.
Are there any performance reasons to flash to 1013? Any new options?
Hi everybody!
I've just got a P5k-E 4 days ago. This is the first time i use a mobo of ASUS. I have some questions :D
First, My E8200 was stable@ 3.8Ghz with 1.375Vcore( BIOS) 1.360(CPU-Z) on mobo P35-DS3P. Now I'm using P5K-E Wifi ( bios 1013). Everything is the same, but it is not stable. The bios 1013 is good to OC huh? Do I need to change the NB Voltage? SB Voltage? CPU PLL Voltage?....etc..
Thank you
Try:
1.55v NB
1.20v SB
1.20v FSB Term
1.60v PLL
Loadline Calibration enabled
CPU Spredspectrum off
PCIe Spredspectrum off
1013 works great for overclocking wolfdales, you should also check your
ram timings, and voltage to make shure its not that.
Also be aware that these (most) wolfdales require a small bump in vcore (.025 - .050mv) to regain initial stability after a break-in period, or after they burn-in so to speak.
What is the lowest bios that can boot up into bios with a wolfdale?
I wanted to share some of my voltage measurements on my P5K-E
Rev. 1.00G w/ bios version 0503
All results tested @ 400FSB
vmch @ 1.25v = 1.55v
vmch @ 1.4v = 1.422v
PLL @ 1.5v = 1.57v
vsb @ 1.05v = 1.075v
VTT (vFSB) @ 1.2 = 1.55v
VTT (vFSB) @ 1.3v = 1.338v
It seems like my PLL voltages differ from the findings on newer revision boards, as I can set it at 1.5 and get pretty close to that even at 400FSB.
I'm a little annoyed that my board has been over volting the Northbridge and vFSB settings by so much, all the while I'm thinking they are at their lowest settings. Good find about these voltages guys!
Does anybody know what some average temps for AUXTIN; this value can be obtained by running CPUID Hardware Monitor. I am getting some really high temps and I don't know what this temperature belongs to.
Decided to try for a higher 24/7 o/c and tested up to 3800mhz so far. This config is 1 hour OCCT Ram Test stable:
I already posted a bit of this in the Q6600 thread but wanted to share my bios settings:
L723A
http://i28.tinypic.com/34dfkzr.jpg
Edited: After 15+hours running Boinc I finally received 2 BSOD's within 4hours of eachother and after testing so far am stable with changes marked above with *Code:CPU Ratio: ........................ 9.0
FSB Strap to North Bridge: ........ 333
FSB Frequency: .................... 422
PCIE Frequency: ................... 100
Dram Frequency: ................... DDR2-845mhz
DRAM Command Rate: ................ 2N
Timing Information: ............... 4-4-4-15-3-52-6-3-3
DRAM Static Read Control: ......... Auto
Transaction Booster: .............. Enabled
Boost Level:.................. 3
CPU Voltage: ...................... 1.5375v *1.55v
CPU PLL Voltage: .................. 1.60v
FSB Termination Voltage: .......... 1.30v
DRAM Voltage: ..................... 1.90v
North Bridge Voltage: ............. 1.40v
South Bridge Voltage: ............. Auto
Clock Over-Charging Voltage: ...... 0.70v
Load Line Calibration: ............ Disabled
CPU GTL Voltage Reference: ........ 0.61x *0.63x
NB GTL Voltage Reference: ......... Auto
CPU Spread Spectrum: .............. Disabled
PCIE Spread Spectrum: ............. Disabled
Question regarding running 4Gb on this board vs overclock.
With 2Gb (2 x 1Gb) I could Orthos all day at 3.2Ghz (400 x 8) at 1.5v, but with 4Gb (2 x 2Gb) the best I can do is 3Ghz ( 333 x 9 ).
Any idea why this is and how I can fix it?
ta
Paul
If you can post your bios settings for your 400 FSB config it would help, you gave to little info to try and help you atm.
Ok a little update before I give more info.
The 3GHz clock, 1.4v, 333x9 was Orthos priority 8 small FFT stable for 18 or so hours. But when I ran the blend test it crashed after 9 hours, so now I'm trying to get the 4Gb (2 x 2Gb sticks) stable at 1066 5-5-5-15 2T.
Bios is pretty much all an auto except memory timings as I have to set Tref to 60 manually. CPU volts is 1.425 which gives me 1.408v in Windows. I've raised the NB voltage to 1.55v and testing blend again on priority 10 (3 hours in). B ut pretty much all the other options, as I say, are on auto as I have no idea what they do lol.
Cheers
Paul
I just tried the vdroop pencil mod and my Vcc actually decreased for some reason, I have triple checked the resistor and used a 2B pencil. Has this happened to anyone else?
I have softer pencils if that would help. I will remove the lead, after I figure out how to, for now.
Hey lads, im having random reeboots and bsods with this board...thought i had dusted an e8200 as it went unstable on me but now this e8400 is getting the same issues...i havnt been above 1.375 vcore so im sure that degredation is not an issue.... can anyone post there stable overclocks for this boarrd with a complete run down on bios settings....the chip boots at 4ghz but wont stay stable...
also im running 2 x 1gb of 1066 ballistix, any issues with this ram?
(p.s i have the 1.86v pll issue now set to 1.6)
cheers for the help lads...
Gordy!:up:
lol....double post there sry!!!:rofl:
Can you explain me what is GTL CPU Voltage Reference guys??
thanks!
Anyone using Q9450 with this motherboard? I'm getting both this motherboard & Q9450 by tomorrow from 'egg. Wondering if anyone can share some BIOS Settings with me for basic OC'ing of Q9450 on this board. Also, will this board recognize my Q9450 out-of-box?
Thanks!
Hey CrazuNutz,
How's it going? I need your help.
Can you point me to a template of the full bios 1013? I need to support a friend over the phone who's OCing this board with a e8400. I can manage walking him through everything I just need to be able to see the list of available settings, how they're organized and labeled.
Our goal is 4ghz with least Vcore possible. I would like to explore 4ghz at 8x, 8.5x and 9x.
Are there CPU and NB GTL settings available in this bios and if so, what is the range? How low can they be set?
Any insight or links to good settings would be appreciated. I've read up on the mystery voltages being applied at auto or min settings - scary!
Thanks.
Thank you so much about your advice CrazyNutz. But can you explain this clearer
"Also be aware that these (most) wolfdales require a small bump in vcore (.025 - .050mv) to regain initial stability after a break-in period, or after they burn-in so to speak"
You mean after I get my system stable. I have to bump a little vcore for stability?
If you have a wolfdale it is very likely so. After a few weeks, you'll notice
prime stability failing. Then you just bump the vcore +.025 - +.050mv
and you should regain prime stability, and don't worry you should not have to
bump it anymore after.
MRCAPE: check your PM
