Originally Posted by
Christopher
B.A.T. --
I'm excited -- I love those damn irritating MTRONs.
The erase count is literally the number of erases (I think it's in 1MB chunks). My 16GB MTRONS would decrease MWI around every 15 000 000 RAW. Unfortunately, because the drive is always doing GC and wear leveling the number is always increasing even if you're not writing to it. You could fill the drive to 100% look at before and after SMART shots, then erase the drive. The Samsung 51nm SLC is rated for 100K PE cycles, so 1 MWI should be 1000 PE cycles. 1000 * 32 768 MB = 32 768 000. Something like that, anyway.
The maximum raw value is 3 200 000 000 for the 32GB, should be 1 600 000 000 for the 16GB (but I have no way of verifying what the hell happens when you get that far).
Your drive is probably ~98.4 MWI if you want to think about it that way.
Writing a 1GB file to the PRO isn't going to tell you all that much. If you do it a couple times, it will be different each time.
I also think I have the .18R FW for your drive, but I would avoid flashing it like the plague. It's not like 4K RWs are going to skyrocket from 0.45MB/s to 0.50MB/s. But I get 46MB/s QD1 Random Reads with my PROs though. So that's nice, and you should be able to get a high avg speed.
