Hi! guys i need some tips, trying to find my max benchable speed on air, 920 D0 on Megahalems and E760 (bios S61B).
Bclk seems to be my biggest problem as it can't go higher than 219 without pushing 1.5v vtt... so far with 1.55v i can do Spi 2M @ 223*21, but afraid to push above 1.55... also room temp is very high..
Is it normal to need a lot of vtt volts for higher bclk? :shakes:
Here's my current test config
Code:
Frequency Control
CPU Clock Ratio (20X + turbo)
CPU Host Frequency (Mhz) ( 223 ) *boot@216 then up with eleet
Target CPU Frequency 4690 MHz
Target Memory Frequency 1340MHz *low for testing
MCH Strap ( Auto )
CPU Uncore Frequency (Mhz) ( 2x memory )
CPU Clock Skew ( 0 ps )
Spread Spectrum ( Disabled )
PCIE Frequency (Mhz) ( 107 )
OC Recovery ( Disabled )
Memory Feature
Memory SPD ( Standard )
Memory Control Setting ( Enabled )
Memory Frequency ( 800 MHz / 2:6 )
Channel Interleave Setting ( 6 Way )
Rank Interleave Setting ( 4 Way )
Memory Low Gap ( Auto )
tCL Setting ( 8 )
tRCD Setting ( 8 )
tRP Setting ( 8 )
tRAS Setting ( 24 )
tRFC Setting ( 74 )
tRRD Setting (5)
RTL'S Settings (76/79/81)
Command Rate ( 1t )
Voltage Control
EVGA VDroop Control ( Without )
CPU VCore ( 1.44 )
CPU VTT Voltage ( +325 ) *boot@150 then up with eleet
CPU PLL VCore ( 1.80 )
IOH PLL VCore (1.80)
QPI PLL VCore (1.150)
DIMM Voltage ( 1.65 )
DIMM DQ Vref ( 0 )
IOH VCore ( 1.20 )
IOH/ICH I/O Voltage (auto)
ICH VCore (auto)
**VTT PWM Frequency ( 490 KHZ )
**CPU PWM Frequency ( 1333 KHZ )
**CPU Impedance ( Auto)
**QPI Signal Compensation ( Less )
CPU Feature
Intel SpeedStep ( Disabled )
Turbo Mode Function ( Enabled )
CxE Function ( Disabled )
Execute Disable Bit ( Disabled )
Virtualization Technology ( Disabled )
*****Logical Processor Setting*****
Intel HT Technology ( Disabled )
Active Processor Cores (All)
*****QPI Controller Setting*****
QPI Control Settings (Enabled)
QPI Link Fast Mode (Enabled)
QPI Frequency Selection ( 4.800 GT/s )
