Your NB speed is 9x looking at your RAM latency, it should be below 48ns if NB was actually plus 2.4G but your L2 cache is too low, lower than real 2.91G Phenom gets. 2.91G gets 3.3s which means you're at plus 3GHz CPU speeds as that's all that effects L2 latency. ;)
What RAM MHz/timings does CPUZ show at those settings?
Cold limits are many times different ;)
You see, so could everyone else I've seen incl. myself and look at tictac's post above mine. It's just that Phenom 9500/9600 did not actually change NB multi plus 9x. Only CPUZ would show it higher speeds than 9x and real software would show you the speeds.Quote:
Well, I guess I'm one of the few that can play with the nb multi.
BUT... but... divide the NB speed AOD shows by the HT ref. you set in BIOS at bootup and I bet it shows the NB multi at 9x. ;) ;) :p:
BE does change NB multi and shows NB speed having big difference on perf and you need high NB volts for that.
*If you want to find out and see for yourself, like I said, just bootup at 266x11.5 3.059G at 9x NB multi and your scores will be like you're getting above, probably even faster.
-Then set to 239x11.5 2.749G and 11x NB multi in BIOS and compare 1M/wpime with your above "2749" scores. It will be a lot slower.
-Then set 217x11.5 2.495G and 11x NB multi in BIOS and compare with above "2530" scores. They'll also be a lot slower.
Not because you didn't oc your NB, you did here too but because your NB was always at 9x and your CPU speed was much much lower in these cases than the shots you've already posted.
You're not setting 2.7G/2.5G in BIOS, you're setting 266x11.5, that's why CPUZ is reading 266x11.5 3.059G.
If you set BIOS at 2.7G and 2.5G, I'd like to see that.
TRUE NB multi moved up above 9x is shown by one clear way: Sandra mem/1M/32M/wprime/RightMark MTMT and most importantly, you can validate the CPUZ (you can't otherwise) and you'll also be able to move HT up to those speeds too. Like this:
Attachment 72123
If no NB multi change above 9x, AOD does not allow higher than 9x HT multi on any Phenom.
Easy tests to prove NB/CPU speeds:
Run Cinbench 10 and POV-Ray 3.7 BETA at (BIOS values):
228HT ref. x 11.5 CPU multi (2622MHz) and 9x NB multi (2052MHz) ->
THEN
Again run at 228HT ref. x 11.5 CPU multi (2622MHz) and max NB multi (if 12x then 2736MHz) ->
Post back the images and scores.
Show both, AOD and both CPUZ CPU/MEM tabs in the image.
Hehe.. that's crazy. What benchmarks have you tested? Can you run the above two tests for me at 9x NB and at your max NB multi?
