Please report your X-Fi problems to Gigabyte tech support.Quote:
Kill was a poor choice of words. Let me rephrase. After flashing to F6b (not F5 Cranox), the X-Fi was no longer detected. It took two cold boots to finally get the card detected so I could re-install the drivers. I'm hoping it works from now on but I'm skeptical.Quote:
Originally Posted by Lestat
Also, I'm well aware of the X-Fi's problems. My card wouldn't even work with my nForce4 board last fall until I returned the card to Creative for patched firmware. That being said, there is no reason why the card should work with one BIOS version and stop working with the next. Obviously, this is a problem Gigabyte created.
Of course, if you have another suggestion for hardware accleration of OpenAL audio and all flavors of EAX, I'm all ears.
There seems to be some new BIOS information over at .......http://www.jzelectronic.de/jz2/index.php
looks like EIST and X-FI Soundcards are some of the things mentioned.
Anyone here that can translate from German?
Google can try. LOL.
All for Allendale the CPUen the new beta use, should the energy administration to continuous operation set. EIST does not function unfortunately perfectly with E6300/6400! The achievement becomes more badly in the EIST condition, even burning procedures can break off. And X-fi sound maps have K.F. Until further notice Allendale owners should take the last finally version. HP.: As it, runs EIST with Conroe CPUen looks problem-free… One works in Taiwan on it and we to expect daily a new BIOS.
I don't know what "X-fi sounds maps have K.F." means. Hopefully it means they're fixing it.
All I can say is **********************! What they can say is be aware of using Beta BIOS is your own risk! It's not fair!!!!!! :mad:Quote:
It is your own risk to be fair... hence the word beta attached :P :D. For me this beta is excellent though, just as a side note I don't plan on getting another PCI sound card (waiting on PCI-E to work with sound cards :))
My g/f is quite good at German, so here's the translation (The news is quite bad!)
For everyone using an allendale CPU in combination with the newest betas: Turn energy usage on max (Personal note: I wasn't aware of such an option maybe talking about QST here?). EIST doesn't function flawless on 6300/6400! Performance will go down in EIST mode, even Burning DVDs or CDs could suddenly break down!! And X-Fi cards suffer form K.F (she could translate that one:D )
So no guesses on what "K.F." is?Quote:
Originally Posted by TheForce81
Killing forsure :p: :stick:
"K"not Found? :p: :banana:Quote:
http://www.acronymfinder.com/af-quer...d&string=exact
apparently it means kung fu
So much for the guy who claimed Tuesday that the betas would become official that same day. These betas have definate problems. The E1ST bug, the X-FI issue is a major one and has only been introduced since the latest betas.
I also firmly belive there are issues with the CPU voltage and Vcore options...i think there is some major wall holding E6600-6700 chips back. Clearly the X-FI issue is something in the PCI bus...possibly overclocking is altering the PCI bus frequency out of spec.
Another issue is the USB Keyboard Support error when using a RAID array, if you enable USB Keyboard Support you lose your RAID array...if you also have a SATA optical attached as well.
Also the Intel Matrix RAID bios rom needs to be udpated + the JMicron bios as well.
hahahaha
Whatcha laughing at?
Guys, are there any issues as to stability with which ram slots you use? (i.e 1+3 or 2+4)
Good question...i think most people use the Yellow slots. Seems standard proceadure...in fact, they recomend this.
ha... that explains. I got E6400 and power mgmt did not work well on Vista with F6b BIOS. went back to F5 final and all is good.
My computer just broke down in some stange way. Cant enter bios either since I dont get far enough to get that option. It just hangs after checking CPU and memory, screen just show
"memory runs att dual channel Interleaved"
and it gets no further, tried to dissconnect IDE, SATA, All USB and to change the memory to single channel and to change memoryslots and of cause CMOS several times. No change, what shall I do???
Originally Posted by Dirt
Dirt i had same problem with f5c beta bios...the reset cmos and take off the battery haven't any effect but to the end fortunately i resolved :)
http://www.xtremesystems.org/forums/...postcount=1044
sorry for my English guys :D
http://justoverclockit.com/pics/dq635.JPG
E6400 DQ6 @3.5
Mine works fine. 2 of my buddy's also work fine. I've ran it in a 925XE, NF4 SLI, and now the 965P. So now you know of 3 that aren't a pile of sh|t. :banana:Quote:
lil off topic but can anybody tell me if they are watercooling their DQ6 with a storm block..and is it difficult? again sorry for being off topic...:toast:
hhmm no new bios's damn...
come on gigabyte your gunna be history shortly if you cant get the gskill d9 and teamgroup D9 memory working. i have no use for a board that limits the ram to such a degree.
