Anyone else noticed that NON Speed Premium sticks use exactly same PCB as Speed Premium sticks? ;)
Maybe thats why M.tec overclocks like :banana::banana::banana::banana:, because they use different PCB.
The_Stilt,
when will you be selling the pre-tested 1GB kits?
and what will you be charging?
zyklon where did you get them ?
i have feeling i won't be lucky getting this ram....
How long should the modules burn in?
Was that Winbond UTT or just a M-tec/TwinMos chip?Quote:
Originally Posted by Zyklon5
Hey Bennah... have a look at these... ;)
http://www.adventurevision.com/somep.../TwinMOSx4.jpg
And in case you missed it... (finger pointing thanks to my 4yr old :))
http://www.adventurevision.com/somep...winMOS-44D.jpg
(all AA4T's btw...)
These were bought from NewEgg.com and shipped from their New Jersey warehouse on Sunday night.
bah damn lucky fookers....what you gonna do with 4*512 ?
:eek: cream of the crop jeff!
AA4T's + 4.4ns
Originally Posted by The Stilt
L U N A T I C ............. :D
I'd like to take credit for them but they are headed over the pond once I make sure they aren't DOA. ;)Quote:
Originally Posted by Playful_Buffalo
I may have to pick up a few since the price... it's just insane! :bows:
Originally Posted by Jeff
256mb sticks right?
those pcb's look like mine! tho they are SP! :confused:
can you plz post their revision? :toast:
So, if i want to get some Twinmos Vx i should look for some ic's with TMD....44D and P/n:......AA4T of late 04?
Thank you!
All people in uk needing this memory.
I have a friend in a pc shop that has just had a twinmos delivery 512 and 256 ;)
I can go and check the stock on saturday and will report back.
I am happy to buy this ram and post it to people but can i get a general idea of how many people would want it and what size modules.
This is quite a small shop without a lot of buying power so it wont be as cheap as the big online stores but i may well be able to get a bulk discount and since they only just got it he isnt actually sure how much he is going to charge :p
I think its min £50 for a 512mb stick and max £60 i think but they will be hand picked :)
Also he is happy to get stock in if he can and knows i will buy it ... a very accomodating chap :). Could someone let me know which distro companies distribute this ram and if they can do specific codes on the ram :) I will pm alonso.
Yeah, all 256Mb sticks... forgot to mention that. :rolleyes:Quote:
Originally Posted by sparkie34
Only mark on the PCB I can find is KO-6633... is that it? If not, where is it printed?Quote:
Originally Posted by enok
are they on the speed premium only or we can buy value modules with Winbond UTT alias Twinmos Vx??
Can someone answer my last question, too? I would like to go tomorrow for shopping :P
Originally Posted by X-GeN
In that listing that was provided earlier, showing the various clocks for the 60Ds, the 50Ds and the 44Ds we left off the 60Ds with the "-50" after the date codes (like X-Gen reported in an earlier post).
These seem to do much better than the 240 shown for the "regular" 60Ds. X-Gen hit 270s and Diablo23rd over at OCForums has a set of these and they maxed his 3.2 P4 at 255 with 3.6v and he was sure they had more left.
We might want to edit the list and include these (remember...these are M.tec labeled chips that have the extra code, not the TwinMOS labels).
These chips can be found in Non Speed Premiums as well. The critical physical markings are the Winbond circles/dimples, the small hole in the lower left corner and the two bands/staples at both the left and right edge of the chip. Stick on labels will end in AA4T and the chips will have date codes with YYWW4, the "4" being critical, the "D" after the date code in NOT Winbond UTT.Quote:
Originally Posted by BeSaiD
Good luck in your hunt.
I got mine from ChiefValue, they are the aadt's... :(
I saw earlier in the thread that transam got the 256 mb sticks from newegg and they were good. I was wondering if anyone has tried the 512 mb sticks from newegg yet and results? i cant find them i must be overlooking if its there. Does anyone know? I really need 2x512 and am using 2x256 of mushkin bh6 right now but want an upgrade :).
Originally Posted by TyphooN
A bunch of people tried 512mb sticks from newegg and got the AADT sticks. :(
Ya.. but not Brain Power PCB
TwinMOS use brain power PCB on AADT not on AA4T? Why? :slap:
From these results I really dont think the BrainPower PCB is that important... OCZ uses BrainPower and does about the same as these modules if not worse so what's the big deal?
yup.. they exist in plain twinmos & the speed premiumQuote:
with 4 last p/n endded with AA4T :stick:
man i really want some 2x512 ram that is bh-5 or this winbond utt, i really hope theres some good twinmos 512 mb sticks :mad:
