Hey what is the name of that Black and Orange fan your using for your CPU cooler? Is it any quiet?
standard thermaltake fan (for case/hs) - no they r not that quiet, there definitely better fans re: noise out there..
Hey, my first post and here's my rig:
http://img379.imageshack.us/img379/9...removedhw6.jpg
CPU: Core2Duo e4300 @ 3ghz w/Noctua NH-U12F cooler
Mainboard: Gigabyte GA-965P-S3
Memory: 2x 1gig G.Skill PC5300 w/silver heatspreaders
Hard Drives: Seagate 160gb sata, Samsung 160gb sata
Video Card: Leadtek 7900GS @ 520/1400
Optical: LiteOn DVDRW
Monitor: Viewsonic VX2025WM 20.1" WS
Keyboard / Mouse: Logitech S510 / Logitech G7
Case: Gigabyte Poseidon
PSU: Thermaltake 600W Toughpower
Speakers: Logitech X-530 5.1
Sound card: Creative SB Audigy Value
Headphones: Beyerdynamic DT231PRO
welcome and can u please state the spec of ur rig, even in ur signature :)
Nice wires
Got me new case yesterday. Antec 182B. And im very happy with it. :)
http://img258.imageshack.us/img258/2...047copyzt3.jpg
http://img258.imageshack.us/img258/7...052copyaz5.jpg
http://img258.imageshack.us/img258/5...050copyon4.jpg
is the chipsetfan not actually needlessly?
You meen if i need the fan over the NB?
Yes i do. If i dont have any fan over the NB it will get very hot (hot in sense that i cant hold my finger on the cooler more than 5sec) and im only running 1,25v on the NB. Then again i run high FSB (460), so maybe thats have something to do that the NB getting hot. But i will get Noctua NC-U6 or Thermalright HR-05 soon.
SeLecT lawl at the monkey
Yeh that Monkey made me lol
@Datanusse: Fanless cpu cooler but bodged on nb fan? :confused:
Antec P182 fits triple rad in top? :)
at least seems yes
yes with mods, looking at this 120mm top fan, seems that is possible to put a triple rad inside, but i dont know what im talking...im just imagining :D
Select, I love the look of the Monkey :D
Beutiful rig...
heres my babe
Mine
Hello all~
After upgrading my main rig (pictures are coming), I decide clean up 2nd rig. Check the SIG for specs.
Main case is Aluminium which was a lot easier to cut, but this antec metal case took me 2 days for cutting..
Followings are what I've done so far:
(1) replaced the one of 3.5" holder @ the bottom for HDD holder.
(2) replaced side panel.
(3) re-route the wires.
(4) both front and rear fans (2 of 80mm) were replaced for 120mm (Yate Roon).
Hope you enjoy the pics and C&C please~
1
http://img240.imageshack.us/img240/5...c001dt2.th.jpg
2
http://img240.imageshack.us/img240/9...c002rh8.th.jpg
3
http://img240.imageshack.us/img240/7...c003yi2.th.jpg
4
http://img240.imageshack.us/img240/5...c004oi2.th.jpg
5
http://img240.imageshack.us/img240/6...c005oz2.th.jpg
6
http://img353.imageshack.us/img353/9...c006hc2.th.jpg
7
http://img353.imageshack.us/img353/7...c007er0.th.jpg
8
http://img353.imageshack.us/img353/8...c008zj7.th.jpg
9
http://img353.imageshack.us/img353/4...c009ec8.th.jpg
Hello all~
Here is my main rig. Check the SIG for specs.
It's been updated from post # 5432, if anyone got curious. It's Aluminium case has been survived for many years, and I finally started cutting some off~
(1) installed HDD holder. ("iCage")
(2) installed front panel which is covering gap from (1).
(4) front fans (2 of 80mm) were replaced for 120mm (Yate Roon).
1
http://img474.imageshack.us/img474/4...y001gu6.th.jpg
2
http://img474.imageshack.us/img474/923/sky002tk2.th.jpg
3
http://img474.imageshack.us/img474/1...y003ip6.th.jpg
4
http://img474.imageshack.us/img474/6...y004om0.th.jpg
5
http://img64.imageshack.us/img64/6171/sky005oz4.th.jpg
6
http://img64.imageshack.us/img64/7328/sky006vb3.th.jpg
7
http://img64.imageshack.us/img64/6030/sky007rm8.th.jpg
[Just got the new DVD Burner for main rig]
8
http://img64.imageshack.us/img64/944/sky008mo1.th.jpg
[Another shot of New DVD Burner]
