I will give it a shot ty.
i know i posted this b4 but no one answered me :confused:
if i go back to default in my bios it boots at 266 FSB and not the 333 FSB.
on the OCing side of it, i got 4 GHz stable:yepp: tho i cant get the vcore any lower then 1.4 in windose. (this is my first time at overclocking) At 3.825 GHz my vcore is 1.29/1.30 in windose.
ill post my settings for 4 GHz tonight when i get home
hi guys: any suggestions to my bios settings??
cheersQuote:
3.60ghz @ 1.38125v BIOS ***currently testing with prime95*** oct 18/08 9:30am est.
using the asus p5q pro stock bios 1106, with G.SKILL F2-8000CL5D-4GBPQ PC2-8000 4GB ram
FSB frequency ==============> 300 x 12
pci frequency 100
FSB strap to northbridge auto
DR ram freq < 800 mhz >
DR ram timing control manual settings
DRRAM Timing Control [Manual]
CAS# Latency [5]
DRAM RAS# to CAS# Delay [5]
DRAM RAS# Precharge [5]
DRAM RAS# Activate to Precha [15]
RAS# to RAS# Delay [5] <--Auto is on 3, too tight
Row Refresh Cycle Time [45]
Read to Precharge time = _____________??? value is 1 to 15
DRRAM Static Read Control [Disabled]
DRRAM Read Training [Disabled]
MEM Overclocking Charger [Auto]
AI Clock Twister [Lightest]
AI Transaction Booster [Manual]
Common Performance Level: [9] <---7~8 maybe possible???
Pull-In of CHA PH1: DISABLED
Pull-In of CHA PH2: DISABLED
Pull-In of CHA PH3: DISABLED
Pull-In of CHA PH4: DISABLED
Pull-In of CHB PH1: DISABLED
Pull-In of CHB PH2: DISABLED
Pull-In of CHB PH3: DISABLED
Pull-In of CHB PH4: DISABLED
DR ram static read control disabled
DR ram read training disabled
MEM overclocking charger auto
AI clock twister lighter
AI transaction booster manual performance level = 9 settings
cpu voltage 1.375v >>> 1.38125v
cpu gtl return .61x
cpu pll voltage 1.54
FSB termination 1.34
DR ram voltage 2.14* want to go lower tho ram is rated 2.1v
NB voltage 1.36 >>>>1.40v
SB voltage 1.20
pcie sata voltage auto
load line calibration
cpu spread sprectrum
pci spread strectrum all disabled
cpu clock skew auto
NB clock skew auto
cpu margin enhancement optimize
in Advance CPU settings:
CPU ratio is 12x
C1E support disable
max CPUID value limit disable
CPU TM function disable
Execute Disable Bit disable
Intel speedsteptech disable
intel C-stateTech disable
Thanks for the new modded Bios
i will Try the P5Q Pro one.
I made also an mirror on Rapidshare
Here the link for you
http://rapidshare.com/files/15527935...06_mBIOSes.rar
Feichti
guys: true or false.... disabling the USB legacy supports helps to prevent RAM/BSOD errors in vista with asus mobos???? i read that on another forum
With 4 modules I would suggest setting the memory frequency at DDR667 and set the memory Voltage to 2.0 Volts and set the NB/MCH/SPP Voltage to +.05 Volts as well and test the system with www.memtest.org. In addition, with some MB's (Mostly ASUS) you have to disable legacy USB in the bios when running any memory test.
__________________
im using 2 instances of memtest v3.01 to test my ram in vista
http://i33.tinypic.com/2ic410l.jpg
OT: is overclock.net down right now? 1am est time oct 19th
Anybody know where do the vdrop pencil mod on P5Q-E
or is not yet known
because my stupid striker has a voltage reg problem and keeps blowing up and so i cant ever get to finish building it :mad: lol
my original gamer is even slower lol its
AMD 6000
m2n-sli
corsair xms2 800 MHz
X-fi xtream audio
2 x 250GB Seagates in Raid o
2 x 8800GT's overclocked
Give up on the gamer and use your lan box as the powerhouse? :p:
Well I have been gone for a little bit of time now 24hrs lol. I figured I would post a pic of what I was doing. I was cutting holes in my case so I could tuck my cables out of the way better and to get better air flow. Here is what it looks like. I know the video card is bending a little but, it will be ok I'm sure. I actually lost my Keyboard and Mouse in this process "the USB wireless controller broke" and my spot cool broke as well.
http://img114.imageshack.us/img114/2010/nowiresyw7.jpg
Not looking too bad in there :up: That nest of cables at the bottom could do with some zipties tho :p:
They are all going into a hole I put there to run the cables out and around the back of the case :p:. I do need to tidy it up a little if possible. Though it's probably not going to be very much, and I need to move that one stray fan wire at the top left, that thing is irritating. :p:
Not quite bigger then the power supply but, I will never have to fill water or worry about a leak and they happen eventually unless you tend to it enough to actually catch it before it can do damage I guess but, still I would rather not have to worry about it TBH.
I still like air better, its easier to move a system using air than it is one thats using water.
Exactly I just don't like the extra work that comes with it I'm sorry.
:D
haha if weight is problem whit coolers
http://img293.imageshack.us/img293/8489/lolje8.th.jpghttp://img293.imageshack.us/images/thpix.gif
