my 400x9 takes 1.38vcore, 411x9 1.440vcore (actual numbers). 4 core small ffts of course.
Have not maxed mine due to old board....but saying that 3.5ghz 1.45v in bios-air- on an old DS4 P965 r.1.0...can't grumble.:)
http://img117.imageshack.us/img117/1...lelargewr2.jpg
Nice one man. I'm sure with some tinkering you can top 15,000 :D . Just a thought, can you back down on memory clock and up the gpu core a bit?Quote:
RLM. Impressive result you got there. So I had to give the beta drivers a go as well. Core temp log shows highest temp was 67 deg under the 3DMark06 Cpu tests. These are great chips and although not stable by any means it sure is fun to rip off a few benches at these speeds on air. Ya still kicked my A$$ by 101 points.
Tomati,
That's a sweet chip there man:D
I'm considering a gamble, trading mine in and looking for a new one. Will have a butchers for an L728A. Would love to be stable at 3.8ghz 1.5v.
RLM
Hi Guys,
I'm new here and want to share my overclock with you guys:
Q6600 G0 L719B272
1,475 Vcore in bios
The temps are too high, I need to do some lapping.
http://i224.photobucket.com/albums/d...abiel14uur.jpg
ARE U TESTING ON AN OPEN SETUP, I AM ON DUAL RADIATOR SETUP AND AT THE SAME SPEED AND ALMOST SAME VCORE, I AM GETTING 3C HIGHER THAN YOU UNDER LOAD AND THAT ON WATER, AND WITH OPEN CASE MY TEMPS GO DOWN ABOUT 5C, I AM HAPPY WITH MY TEMPS BUT I REALLY DONT GET HOW SOME PEOPLE GET SUCH LOW TEMPS ON AIR, MAY BE ITS THE CHIP, O WELL.
well, i can tell you that my setup is sitting out on the bench...once i put it inside the case, i will have a comparison difference...i will post back with the results.
NKD
Global warming?
"E6850 with Abit IP-35 Pro board
8800 ultra msi oc edition 660core/2300 memory.
ultra x3-1000 watt power.
high end watercooling setup with d-tek fusion waterblock.
average room temp 68-72c" :eek: :D
1.2125 VID chip, with 1.408v after vdroop Tuniq Tower 120 would give up, 83C+ and bsod. Now with TRUE I can do a bit better (10C less than on Tuniq):
http://img205.imageshack.us/img205/1112/g036di7.jpg
25C ambient temp, I primed before couple hours, now I just did 10 min. to make a screenshot.
Somehow disappointing, pwm flaming hot. This chip is capable of doing 3.4Ghz @ 1.29v, 60C load after vdroop stable for hours. Up to this point I have remounted TRUE 3 times using 1.5' galvanized washer and AS5, I know for a fact that those were all perfect mounts because I still get same exact temps. Before I remounted Tuniq 6 times and got different results each time. I don't know why this cpu is so hot, pulling to many amps perhaps, good thing is that I got transpiper on LP, without it I was hitting 85C on pwn. I'm looking forward buying penryn when it's released, I'm sick and tired right now with this cpu.
lol ur right man, i am in huntington beach, ca, it never hits 90's here, the hottest days stay in the upper 80's but hey the last two days almost hit 100, so yea global farming. lol.
Need_for_mhz- ur temps are probably normal, with my water setup at 3.6 i hit 69c but thats the hottest time of the day, the coldest i have seen at 3.6 is 63c, but i am running 3.5 as my 24/7 setup and i am quite happy the temps always stay under 65c. i think its very helpful to know if people are reporting temps from an open setup or in-case setup, cuz the temps could be 5-10c different.
no not really, as some over at OCAU has found out something pretty important:
http://forums.overclockers.com.au/sh...d.php?t=603324
So, for a 24/7 "safe" overclock with a:
- Core2 quad core CPUs have a higher throttle temperature and so should only be run no closer than 25C from the throttle point.
this was quoted in that thread (link)
Can some one post up best weeks or batches
starting to put mine back together with a Kayl frozen SS 3/4Hp
here is my first nights work...
http://img104.imageshack.us/img104/6...sbench3aa5.jpg
I have an L723A (not one of the better weeks, according to some). It is stable at 400x9 at a very nice, low, 1.38 vcore. But, the thing won't run stable at any faster speed, no matter how much voltage I give it. :shrug:
http://i90.photobucket.com/albums/k2...01.38vcore.jpg
Anyone running an overclocked Q6600 (or better) on a P5B/P5B Deluxe?
Hi there!
Yesterday recieved my new processor, a Q6600 L723A963.
Max FSB validated with aircooling with an ASUS BLITZ FORMULA (My ABIT IP35 Pro is a turd and doesn't let me go over 472MHz):
http://img131.imageshack.us/img131/1861/cpu2898gu3.png
Then I tried 487MHz but the computer froze up. I'm pretty sure it can validate at 485MHz FSB.
Maximum speed validation (air):
http://img158.imageshack.us/img158/1907/cpu4203ff8.png
Having fun with Cordovader's crossfire and my CPU at 4GHz:
http://img517.imageshack.us/img517/5...6282lg4.th.jpg
Superpi 1M @ 4GHz 2/ 1.52v load (1.54v IDLE) w/ ABIT IP35 Pro:
http://img115.imageshack.us/img115/2...idlepv5.th.jpg
WPrime 32M @ 4050MHz w/ABIT IP35 Pro:
http://www.hwbot.org/result.do?resultId=642956
Next week I'll recieve one of Kingpin's F1 LN2 pot. Hope to have a good time with LN2 and this CPU :D
:p
here is my 24/7 q6600 overclock.
Q6600 g0@ 3.76GHz (8 X 470)
2GB Gskill DDR2 1:1@ 940Mhz 4-4-4-12
8800gts 320@ 621/1900 (temporary, waiting for 9800gtx in Nov. to go high end)
ASUS P5k Premium Black Pearl Edition
Custom Watercooling (Swiftech Apogee, Eheim 1250, 3x120mm rad, 1/2 ID tubing)
http://forums.extremeoverclocking.co...7&d=1188446347
2nd screen is my highest boot into windows. 4.095 Ghz 9x455 1.625v (could not get past 4.1Ghz without an insane amount of voltage)
http://forums.extremeoverclocking.co...3&d=1188886543
Screen? Where? :D
Using my nvidia 680i BFG P30 bios... I can only boot in windows if in stock everything..
I was using previously a C2D @3.8GHz with the fuzion and using vista x64.
Normally would run @ 3.6 @ 1.35v to be safe.. Ideas on why I can't overclock like i did before?
