that 3700+ could be dangerous to mine, if this chip work so good with deep temps... no validation over 3.8ghz?
hehe ok :D
next weekend will my 4000+ meat dice... hallo 4ghz :)
That is unbelievable, bruce. Congratz ;)
You are a dual core junkie...
I have tested the new DFI Venus board and here is a first result of maximum HTT with an china cracker 3400+ Venice E6 0613 AAC :D
http://valid.x86-secret.com/show_oc.php?id=276587
That Venus board is great.....
Tried my 3800+ venice, quite nice chip. http://valid.x86-secret.com/show_oc.php?id=276624
And the 3500+ venice WR. http://valid.x86-secret.com/show_oc.php?id=276627 3669.91mhz:D
Unfortunately, the poor thing died @ 1.94v:( :shakes:
Congratz ;) May he rest in peace...
@ Turrican
Much more otions for voltage:
2.0 v @ chip for example or 4.1 v @ dimms ;)
Can boot with 550 mhz htt than the normal 456 mhz @ all dfi.
Today I got an 4000+ 0626FPMW....gianni, I will hunt you ;)
By the way: also got an X2 4200+ Manchester and an 3500+ Venice E3.
tell me the last line....
@ gianni
Looks like F60726 on the end, the other numbers I cant see...this was an ebay auction with a small picture
hey guys check that only 24 of 54 left and bruce/stunned/me will own all s939 wrs :D
http://www.ripping.org/database.php?socketidwr=939
turrican, you have to crack a wr or "you are dismissed" :D
may be with a sempron, hehe :p:
Haha nice! Note that there is a Windsor there as well (please remove the damn thing from the 939 list), and I own a 3500+ sempron (same as 3400+ but with the incredible amount of 256kb cache!!!).
I have what I hope is a decent X2 4600+ manchester in the mail at home, but I need some cash to pay for customs:D
The 3200+ winch record could be hard. I have a chip, but not sure it's good enough. 3500+ newcastle/clawhammer - I don't have either of those. I THINK a newcastle is in the US somewhere, but I wont get it for a little while at least. 3800+ venice is a DAMN hard one. Hope the new CBBLE 0512 is great. The 0449SPAW sucked bigtime, horrible coldbug...
3800+ newcastle doesn't look too hard, but I don't even own a chip atm:p: 4000+ clawie, no idea how great that score is. I'll try my CAAZC 0442GPMW next time I play with dice;)
FX53/55 claw... damn hard to get I think. My chips aren't good enough:( FX55 SD is mine as soon as I try it on LN2:D That chip is as good as my 3700+, and with an unlocked multi it'll be alot of fun:D fsb360@dice/low temps. I'm pretty sure one of us have an FX57 that can beat before. I saw 4ghz on dice on a lousy pot, but got no valid...
X2 3600+ manchester is mine as soon as the chip arrives;) X2 3800+ manchester... don't have one yet. I expect to get a very nice Toledo soon, maybe I can crack that one;) X2 4200+ manchester, don't have one atm... That Toledo WR is too hard for my ACBWE I think:shakes: X2 4600+ manchester, hopefully my new chip is good enough. Just need a little bit of cash so I can pick it up at the post office (damn taxes...) Opty 144,146,148 and 154 will be hard. My 144's didn't like that high fsb, maybe I can get the 148wr, but not sure until I get it and test it. Opty 154 will be DAMN hard!
I think I actually have one of each sempron that's not my own WR yet. I never make semprons pri1;) But next session, maybe. I haven't got so many chips to test now...
3500+ clawhammer WR will be mine, I have a good one coming in :)
3800+ Venice will be mine (with cascade or ln2) ;) fsb 375mhz on really low temps!! with my fx-57 i think i couldn't crack the wr of before...
will retest the following cpu's under dice: 3200+ (wr chip), 3400+ (wr chip), 4000+ (wr chip) :D and maybe once again the FX-57 but these temps are too much for dice... my idea: order ln2 for next weekend. but the minimum order is 50L and thats really too much for two amd chips.... :(
next year i have to travel to germany to a oc-session with (hopefully) a quad-stage-cascade :D
@ gianni
where do you want do got to that session ?
@ massman
I also have one 3500+ clawhammer here without heat spreader but that 3.5 ghz are very hard.
@ bruce
yesterday I got my 5. FX-53, will try to go over 3.4 Ghz....
My first FX-53 was an AAABC 0409 UPMW but at that time I didn´t have the single stage and I didn´t know about overclocking.
Stunned_guy, what does the chip do on air cooling? The chip I have incoming does this on aircooling using 1,55v and is most likely limited by the motherboard.
http://valid.x86-secret.com/cache/65506.png
CBBHD stepping by the way ;)
in a few days mit opti 148 arrives. hope it will be a good one :D
@ massman
i didn´t test with air cooling, but under single stage i got more than 3.1 ghz with default vcore....
my step is CAA2C 0507 BPMW.
by the way: you mean an 3500+ winchester like on the pic but i spoke about an clawhammer.
