It depends, some 0610 are excellent, some are worse.Quote:
is it true that the earlier 904 batch is supposed to be good?
that seems to be the general conclusion... speaking of, my 904 is officially for sale nowQuote:
Originally Posted by blazin-asian
Yeah, 904 is the best of the two that are in circulation. 3Ghz at 1.456v for me. My results have been from the 904 variety.Quote:
here's a good start
Um, I have a 904 too, and it takes me 1.55V to run 3.0Ghz, and that isn't prime stable, just 3D stable...and it takes about 1.45V to run at 2.9, and I think it might need more, or my windows could be corrupt.Quote:
What variations do we have so that we can determine why this is? Well, first off, my ambient temps are horrible, it's usually at least above 29C here...but, I have the IHS off, so my temps NEVER go over 45C, basically no matter what voltage. Could be I'm still holding myself back by other bios options though, but I could imagine what. I've done some pretty exhaustive tweaking.
Second, my whole batch number is as follows: 1434904C60509...notice the last three digits? I believe yours is 70X, and mine is 509...
itznfb, what are the last three numbers of your batch?
On a side note, I think I might need to reinstall windows:( <-------pwned!@#
Hey, do you think you might be slightly mobo limited???Quote:
my batch is 1434904C60987
i have to reinstall windows all the time, i corrupt windows on a weekly basis, if not more, and this WILL effect your overall OC
i actually know i'm quite mobo limitedQuote:
Originally Posted by phi|os
Hmm, I will definitely mull this over, lol. So what do you think the last three numbers specify? The actual CPU #? That would mean I have the earliest between Thunder, you and I; Thunder would have the "middle child", and you'd are the youngest...just an entertaining thought, I have no way of knowing...Quote:
yea, i have no idea what they mean, all i know is the stepping break down.
Dunno if batch number is relevant. Too many inconsistent results to say something like "lower is better".
http://valid.x86-secret.com/show_oc?id=93926
Heres my result on my 170 CCBWE 0551 UPMW
http://rigshowcase.com/img/281aOTVr/4231
nice. i like the hitman bg too ;)
Mine was 434 IIRC, and needed 1.53v to do 3ghz not prime but 3D stable.Quote:
as a little side note:::
i got this chip to boot into windows 334x9 @ 1.25v, but it wasn't even close to stable, it rebooted while opening cpuz =\
still impressive, i may not be selling this chip.
Some days ago got mine, its CCBBE 0610DPMW, max stable with default votage and default cooling was 310 x 9, its ok I think, with 1.375v it goes 2.8+ Ghz! Hope burnin will help me to get 311 x 9 stable with 1.35v or less :D Booted easy into the Windows with 3Ghz and a little bit more voltage, must repair waterhead to lower temperatures! :p:
<a href="http://img180.imageshack.us/my.php?image=310x9prime7bb.jpg" target="_blank"><img src="http://img180.imageshack.us/img180/2170/310x9prime7bb.th.jpg" border="0" alt="Free Image Hosting at www.ImageShack.us" /></a>
hey man looks like u are on here too!Quote:
Originally Posted by Kashelz
sure, also reinstalled SmartGuardian a few times and also MBM and Everest / Sandra report same temp. I will try to reinstall nF4 drivers. If that doesn't help i'll consider reinstalling Windows.Quote:
Originally Posted by Repoman
Well, finally got all my parts, and have been stress testing everything out...
So far, for my 0609, I have:
It was memtesting before for 6 passes.
It is trying to be prime stable ..so far :
[IMG]http://img355.imageshack.us/img355/4...est46kt.th.jpg[/IMG]
Looks like my case *sucks*:shock2: , and needs cooling for the PWMIC (this is on a DFI Ultra-D). Wonder what the limit is for those? 90C?
Oh, this is on air cooling with a Freezer 64 Pro.
^yeah probably around 90. But of course lower temps provides better performance.. you can test if it's performing like it should be measuring your vcore and vdimm with a multimeter, if it's stable then the temp is fine.
PS ITZNFB- can you test the lowest voltage stable @ 3GHz? That would be a good indicator of overall performance of the chip :) I'd really appreciate it.. if it can do it at a way low voltage it may just force me to pick one up :(
edit: actually thats a way good sign, mine is stable at 3GHz@1.425v but it BSOD's on boot at 1.35 and sometimes 1.375, depending on temps :eek: So your might be stable at stock or less
i think the chip will yield much better results on a Ultra D, or SLi-D/DR than the board i'm using. plus my best cooling solution at this point in time is a TT Big Typhoon =\
i'm guessing i'll hit 3ghz @ 1.5v, maybe 1.475v. on a better board, who knows. but i may be way off, i haven't seen how this chip scales yet.
If it's anything like my chip, it will be stable at 3GHz@1.325-1.35v
Where'd you get it, tankguys? If you can hit 3GHz@ stock volts or a bit over I'm picking one up.
I have got batches 0099 and 0368 and between the two the 0368 is much better ;)
I ve reapplied AS5 and retightened the Alphacool waterblock and managed OCCT stable at 1,47VCore at 3 GHZ. Both are 904 series.
http://img329.imageshack.us/img329/9...30063dz.th.jpg
I was able to boot into XP and play games at 1.41VCore /Oblivion /Quote:
lower VCore was a nogo.
