OSKAR_WU posted something about problems with high FSB and SATA.Quote:
Originally Posted by bigtoe
I´m not sure if the problem was with the 1 & 2 SATA or 3 & 4. Someone wrote It was only with 2 of them but I'm not sure wich ones and I can't find that post anymore.
What SATA port did you use?
I'm running on ports 3&4 without problems but I'm only running 250 FSB (I think my problem is mye ram) If I buy some 3500EB I´ll go for higher FSB so I want to be sure I'm on the correct ports.
