Problems that might apear on watercooling systems.
http://fredrik.hubbe.net/silence/wat...intenance.html
i had big problem when i overclocking my e6600@3200 8x400 3dmark06 score go down about 6600pts. stock clock i get about 10000
Sambe, what is the memory frequency ? What GPU ?
BFG 8800GTX OC with EK Fullcover block. i have Mushkin XP2-6400 4-4-3-10 stock value FSB/Mem 1:1. I have f5h bios
-> ChrissTi: Thanks! Guess I got some protozoa in my system, mutating and finally taking over my central nervous system (read PKD 4more)...whatever, this' the highest I'll get, before improving my cooling system. Greetz from SwaziakaSwizzaland
http://192.168.2.169:80/OPEN4ALL/3680.jpg
Hornet..please post pics if you can, high res if you can...pics of the various chipsets etc., so we can see the differences in the PCB.
Also, did you buy it retail...and where?
hello
are people having any fun oc'ing past 1066mhz with the new beta bios?:wiggle:
X38-DS4 now listed at GB:
http://www.giga-byte.com.tw/Support/...ProductID=2736
My system mem speed is 1080 with the latest F7H bios 5 6 6 18 :wiggle:
and I guess I could do more if my memory were identical. Right now they are 2x1G ADATA Extreme Edition 800+ and 2x1G Team Group Extreme 800. I'll wait and see maybe I'll get one 2x2G 4 4.. at 1066, but right now they are too expensive here ... about 1000$ :confused:
X38-DS4 does not have Quad-Triple Phase Power ...
DS4 dosen't have 12 phase, it has 6 phase...which is why it's cheaper.
Which ACPI suspend type is best?, S1 or S3?...S3 is enabled by default...what is the difference in the two?
I read the Wiki explanation for S1/S3...but what setting do most of you guys use?....i normally use S1.
S1 - Power to the CPU and RAM is maintained
S3- Only power to the RAM is mainained ...
S3 is good if you have an UPS, or windows vista which saves Mem data to the HDD before entering S3 (combination beetwen hibernation and S3) :)
Based upon the PDF manual for the X38-DS4...it appears the bios flash parts have been changed to a Winbond 25X80 part. What does this mean in practice?
http://www.eeproductcenter.com/artic...leID=181503961
Hmm..the Winbond flash looks as if it'll be much faster at flashing bios then before.
S3 uses less power of corse :) is just the mem powered
as promised, some screens:
(sry for the average quality, the shots are only taken with my backup camara)
if you need other areas just say it.
Gigabyte GA-X38T-DQ6 Rev. 1.1
http://img176.imageshack.us/img176/6...viewhc0.th.jpg
Cpu socket:
http://img527.imageshack.us/img527/9...orthzu3.th.jpghttp://img527.imageshack.us/img527/4296/cpujl0.th.jpg
Northbridge and surroundings:
http://img299.imageshack.us/img299/2...dge2nn2.th.jpghttp://img527.imageshack.us/img527/6...idgexq0.th.jpghttp://img444.imageshack.us/img444/9...idgebe1.th.jpghttp://img299.imageshack.us/img299/9...outhdo5.th.jpg
Southbridge and surroundings:
http://img514.imageshack.us/img514/3...dge2hz0.th.jpghttp://img514.imageshack.us/img514/5...idgevq2.th.jpghttp://img444.imageshack.us/img444/2...naelro2.th.jpg
Bios Area:
http://img525.imageshack.us/img525/7256/biostn1.th.jpg
chips say:
MX -15G
25L8005M2C
2W71660
googled it, they are by Macronix (Datasheet)
Voltage regulators:
http://img265.imageshack.us/img265/116/vrmsmj2.th.jpg
Power connector area:
http://img444.imageshack.us/img444/4...rramir5.th.jpg
Various shots:
Bottom area (with rev 1.1 sticker)
http://img444.imageshack.us/img444/4701/rev11ti4.th.jpg
Realtek Sound:
http://img444.imageshack.us/img444/7...ltekgx2.th.jpg
Pci 1x area:
http://img527.imageshack.us/img527/8...lotskv4.th.jpg
Realtek Lan:
http://img444.imageshack.us/img444/9913/nicvn3.th.jpg
Gigabyte Sata controller:
http://img299.imageshack.us/img299/6...sataep8.th.jpg
sorry to sound a bit behind > where do you down the latest x38-dq6 bios?
i'll like to see if its fixed the dual channel 1066 problem
you did very well to tune your baord at 1080 with 4 unmatched modules.:)
thanks for any help:)
good luck tuning your new board hornet331 be interesting to see how it compares to the x38 dq6.
still waiting for my ram. :(
and i have a bad feeling that i wont see it befor the new year...
