Originally Posted by kimandsally
I have found my problem, I was using the floppy that came with the motherboard, I carefully read the pdf manual and it says to take the drivers from the cd and put on a floppy, I did that and windows xp has just finished loading :) So maybe I need to be a little more carefull when reading the manual.
I still think you overclock is fantastic, I can only get mine to boot into xp at 300 fsb max with the ram running on the 133 divider, but to do any benchmarking I can only run it at 295 fsb. I am also running the ( Northbridge ) I can't think what it's called on water, and the cpu, although it's not the best water cooling, Zalman Resorater, I am very happy with it the temps are kept down to 43 c most of the time :)
My cpu is a week 46 I think but the Northbridge chip is one of the older not so good ones.
Thanks for you help .
