the turbo clock feature is also disabled. even now it's still downclocking to 800mhz with my 4ghz 24/7 OC setting. weird..
try the F8F bios
using it and it does not downclock
also theres no F8G on the giga website
they ha a F8H but the links are dead
cheers
but some how the voltage on the CPU sometimes goes craisy keeps raising and coming down until it freezes
this on F8F
oops
does any one downloaded the F8H bios ?
giga site the links are dead :confused:
Maybe if you ask Gigabyte, you'll get F8H. They sent me the F8G BIOS.
Hey guys did u tried Ctrl + F1 while in F8H? they said there is a CPU control option.
for what ive been testing this F8H is the most stable bios
it only bumps the defalt vcore to 1.475 put i can run the 1090T at 4.125mhz at 1.350 just need to lower the voltage now becouse the default vcore is higher
this bios does have some problems including the f8G that show the cores downcloking in CPUZ only F8F show cores at allways the speed of the OC in CPUZ but for me F8F was crasy had to enter all the times in the bios config and save setings becouse it never aplies them in the 1º boot and vcores some how allways at 1.600 , but the problem in this 2 bios F8G and F8H is CPUZ related becouse the cores are at the oc speed all other programs show the all 6 cores at the same speed whith AMD coo and quiet off and core turbo off ive test it with 1.52 cpuz and shows the cores at same speed only the latest 1.54 cpuz version was some quind off flutoations
cheers
Yea, after a frustrating night with f8f I went back to f8h. f8f didn't want to play nice with my RAM at all. Vcore got bumped very high after a crash, so anyone running f8f be careful. f8g/h doesn't seem to suffer from that, nor dodgy ram clocks.
i have receved a msg from gigabyte becouse when a while ago i could not download the F8H from there site from some reason , heres a response :
Attach is BIOS for supporting 6 cores CPU. You should be able to update it and try again later. After bios updating, please do not forget to load BIOS fail-safe default setting and please also do not try to overclock your system at this moment.
For more information about BIOS upgrading, please click HERE.
Regards,
GIGABYTE TECHNOLOGY
so it means that there will be another bios from what i think
better then this one
after few tests and iam still testing my cpu works a 4125mhz 1.300v / NB 3000mhz @1.160V / CPU/NB@+225 /HT 4500mhz
heres gos few tests whith diferent mem specs and ht lower and higher
also starting to test the CPU at 4500mhz and its stable at 1425v whith the other seting i stated above
http://img13.imageshack.us/img13/4166/x62h.jpg
[COLOR="SandyBrown"]
http://img708.imageshack.us/img708/1186/x6testmdk.jpg
Uploaded with ImageShack.us
http://img30.imageshack.us/img30/787...ex6testmdk.jpg
http://img521.imageshack.us/img521/8789/temps2.jpg
http://img52.imageshack.us/img52/2518/test1dg.jpg
http://img707.imageshack.us/img707/24/test2zv.jpg
http://img530.imageshack.us/img530/2496/test3w.jpg
http://img704.imageshack.us/img704/6541/test4e.jpg
http://img7.imageshack.us/img7/4383/tempsqb.jpg
http://img188.imageshack.us/img188/7311/46012339.jpg
http://img404.imageshack.us/img404/1640/81974322.jpg
http://img707.imageshack.us/img707/9081/17393948.jpg
http://img51.imageshack.us/img51/4803/11175517.jpg
http://img695.imageshack.us/img695/9647/16131524.jpg
http://img714.imageshack.us/img714/7112/24720318.jpg
http://img51.imageshack.us/img51/3724/23384274.jpg
http://img402.imageshack.us/img402/578/71212305.jpg
http://img186.imageshack.us/img186/9900/mem4.jpg
http://img405.imageshack.us/img405/9287/mem3.jpg
http://img52.imageshack.us/img52/1852/mem2w.jpg
http://img265.imageshack.us/img265/4875/mem1x.jpg
http://img196.imageshack.us/img196/3690/cpuz2hh.jpg
http://img708.imageshack.us/img708/127/score1.jpg
this is my precious a pal here was same specs as me and cant do the mhz the same voltages i have think this is a very good cpu
still doing tests
for the best 24/7 setup
Six cores at 4.5ghz with 1.4v, on air? wow man, great chip! Need some stability tests though :)
What bios was this on?
