This article is really helpful explaining strap and memory performance
I has been over a month since the latest BIOS 0907 came out. What are they thinking?
I think, they have enough to work with other boards. Next bios will come....
Yea man it definitely did......well it sucks but I'm going to look for the best performance setting. This seems to be the only way to get the dividers stable past 400 FSB (maybe 415......)
I'm going to test voltages and such tonight.....I'll post my final results.
So far I'm SuperPi 32M stable with relax 2.....failed at relax 1.
I may be able to make up for lost latency/bandwidth by tightening timings.....
It's really interesting how the same board performs differently for each person. I've managed to find a stable spot with Transaction Booster set to disabled and relaxed at 0. At least it's Prime and OCCT stable. I haven't tried SuperPi..
the dividers are stable for me past 400FSB
I run the 333 strap with a 478FSB and get great bandwidth, I've even had the 266 strap stable on a 450FSB
http://i237.photobucket.com/albums/f...00_1147ram.png
I'm wanting to flash to 0907, but the file is too big for a floppy disk and I have no USB flash disk, how else can I flash to 0907 without using the the utility in windows to do it since I've heard bad things about doing it that way?
Asus update, but not recommended. (Don't even sneeze while it's flashing :D)
Edit: A fat partition on the jmicron controller? An ipod? A blank CD?
I have used Asus Update 3 times and all were a success, I would recommend NOT running an overclock while you flash in Windows
Edit.
yeah I could burn it to a CD, will that work with ez flash?
Hey Zucker2k
What are you running your 8400 for 24/7 use?
I'm getting split screen in 3DMark06 if I go higher than 500FSB
EDIT
8.5 x 506 fsb @ 4.302Ghz
333 strap
transaction booster disabled, level 1. (= PL 8)
FSB:RAM = 1:1 @ 4-4-4-10-2-25-6-3-8-3-5-4-6-4-6, 2.40v (2.20v set in bios)
CPU= (gotta test) 1.3750v (set in bios), cpu-z reports 1.376v, load
CPUPLL = (I set 1.5), you can set to your liking
NB=1.45
SB=1.100
FSBT=1.48
LLC = Enabled
SB 1.5 = 1.60
CPU GTL=x61
NB GTL=x67
I am running the supreme card. Problem is I have a 4.1 altec lansing sound system . this was a $300 system alot of years ago. With my msi neo 2 system it was great useing the spdif out rca. Im using that now BUT I ONLY GET SOUND WITH TWO FRONT SPEAKERS. Our supreme card wants only one plug in for rear speakers. Well I have TWO that mormally plug into the woofer.
SPDIF is being handled diff here.
If I can get a signal out to both REAR speakers I have from the ONE port of the card. WHAT can i use to tie in the second input. It looks like I MIGHT NEED A SPLITER HERE????? WILL A SPLITER WORK ? If I can resolve Im going to have to go LIVE platinum setup. I would rather not add that expense.
Anyone got solid experience? Should I post this somewhere else?
BIOS 0601 out today for the P5E. Maybe we're next?
Has anyone figured out how to OC E8400 to 400 FSB yet?
That's easy for these chips. Why? Having problems?
:confused:
Do to the nature of this thread is why I asked. I haven't found any configs using E8400 (maybe I missed it). Would like to know any tweaks.
http://i11.photobucket.com/albums/a1...MaxFormula.jpg
http://i11.photobucket.com/albums/a1...a_SuperPI1.jpg
Not bad at 3.6GHz
Hello! Here are mine, with the help of some people on this forum. If you look, I think a couple others posted their settings. Zucker just did, and you can find Grnfinger's HERE. I had to stop at 4.23 because I'm using a lot more vCore than most people are reporting. You should be able to get this stable with a lower vCore. I don't know what's wrong with my setup, but I need all 1.4375.
Ratio CMOS Setting : 9
FSB Frequency : 470
PCI-E Frequency: 100
DRAM Frequency: DDR2-1182
DRAM Command Rate : 2T
DRAM Timing Control: Manual
CAS# Latency : 5
RAS# to CAS# Delay : 5
RAS# Precharge : 5
RAS# ActivateTime : 15
RAS# to RAS# Delay : AUTO
Row Refresh Cycle Time : 25
Write Recovery Time : AUTO
Read to Precharge Time : AUTO
Read to Write Delay (S/D) : AUTO
Write to Read Delay (S) : AUTO
Write to Read Delay (D) : AUTO
Read to Read Delay (S) : AUTO
Read to Read Delay (D) : AUTO
Write to Write Delay (S) : AUTO
Write to Write Delay (D) : AUTO
Ai Clock Twister : Strong
Transaction Booster : Disabled
Relax level: 0
CPU Voltage : 1.4375
CPU PLL Voltage : 1.5
North Bridge Voltage : 1.49
DRAM Voltage : 2.18
FSB Termination Voltage : 1.40
South Bridge Voltage : 1.050
CPU GTL Reference : 0.63X
North Bridge GTL Reference : 0.67X
DDR2 Controller REF Voltage : DDR2-REFF
SB 1.5V Voltage : 1.5
MY e8400:
Ratio CMOS Setting : 8.5
FSB Frequency : 500
PCI-E Frequency: 120
DRAM Frequency: DDR2-1000
CAS# Latency : 4
RAS# to CAS# Delay : 4
RAS# Precharge : 4
RAS# ActivateTime : 8
RAS# to RAS# Delay : 3
Row Refresh Cycle Time : 42
Write Recovery Time : 6
Read to Precharge Time : 3
Read to Write Delay (S/D) : 8
Write to Read Delay (S) : 3
Write to Read Delay (D) : 5
Read to Read Delay (S) : 4
Read to Read Delay (D) : 6
Write to Write Delay (S) : 4
Write to Write Delay (D) : 6
Relax level: 1
CPU Voltage : 1.4625
DRAM Voltage : 2.16
FSB Termination Voltage : 1.20
CPU GTL Reference : Auto
North Bridge GTL Reference : Auto
DDR2 Controller REF Voltage : AUTO
SB 1.5V Voltage : 1.6
19454 '06:
http://service.futuremark.com/compare?3dm06=4955818
28241 '05
http://service.futuremark.com/compare?3dm05=3956233
72125 '03:
http://service.futuremark.com/compare?2k3=5710376
78639 '01:
http://service.futuremark.com/compare?2k1=9326703
245219 AQ3:
http://www.xtremesystems.org/forums/...1&d=1201705524
