My mistake 2DIFF
Correction Normal CPU Vcore: 1.325
2DIFF Try to test Your mem settings with Prime an also change your PSU. 700W is not enough for your ATI Crossfire and overclocking ;)
My mistake 2DIFF
Does anyone have the new F7h beta bios?
http://www.jzelectronic.de/jz2/index.php
They are also listing F1 bios for an X38-DS4 mobo?
-> ChrissTi: Thanks for your advice. I always test with Orthos. Unlike you, I have to raise FSB and MHC voltages to reach 3.520 Ghz and I always have to stay with a DRAM:FSB of 1:1. Above 440 Mhz FSB is no stability. I disagree with the fact that 700W isn't enough. This IS my new PSU. Had a 500W Seasonic before and was running 2 X1950Pro's in CF, with a CPU/FSB OC of 60% (on GA-965P-DS3). It's a miracle to me how you get 3.62 Ghz on air. Without cooling the NB with water, I can't OC anything. Well you have the DQ6, I have the DS5 - allthough I don't see any other difference than the LAN-Chip, it seems that there is more OC potential on the DQ6.
Heat heatpipe design:
About heatpipe: I cut mine in half (or better three pieces) and trashed the NB-part. The whole thing is cheap (feels like junk) as hell, and: what's the idea of transporting the heat from the NB (which heats the most) to the SB and the convertors via heatpipe? Since I don't have them connected anymore the SB and convertor part don't even get hand-hot.
Need advice: Wow much performance gain would I probably get by putting some Crucial Ballistix 2x1GB, DDR2-1066, CL5-5-5-15 (BL2KIT12864AA1065) in this system? Price is very low at the time, and chrismas and all of that, so I was wondering...thanks
Got my new G.Skill 8000 PQ 4Gb and I would like to share timings and settings with you guys (with anyone who has this babies at least).
I'm running an E6750 @ 450x8 = 3600Mhz with vcore 1.35v (Everest says 1.34v, CPU-Z flutuates between 1.328 and 1.344)
RAM with 2.40 divider @ 1080Mhz with 1.98v
Everest timings dump:
Memory Timings:
CAS Latency (CL) 5T
RAS To CAS Delay (tRCD) 5T
RAS Precharge (tRP) 5T
RAS Active Time (tRAS) 15T
Row Refresh Cycle Time (tRFC) 54T
Command Rate (CR) 2T
RAS To RAS Delay (tRRD) 5T
Write Recovery Time (tWR) 17T
Read To Read Delay (tRTR) Same Rank: 4T, Different Rank: 6T
Read To Write Delay (tRTW) 8T
Write To Read Delay (tWTR) Same Rank: 13T, Different Rank: 5T
Write To Write Delay (tWTW) Same Rank: 4T, Different Rank: 6T
Read To Precharge Delay (tRTP) 7T
Write To Precharge Delay (tWTP) 17T
Refresh Period (tREF) 4213T
DRAM Read ODT 3T
DRAM Write ODT 6T
MCH Read ODT 8T
Performance Level 7
Read Delay Phase Adjust Neutral
DIMM1 Clock Fine Delay 7T
DIMM2 Clock Fine Delay 7T
DIMM3 Clock Fine Delay 8T
DIMM4 Clock Fine Delay 7T
I got a blue screen just half an hour ago while browsing some photos... Everest stress test won't crash within 5min. Maybe is the memory too tight and bluescreening my system?
Thanks in advance for your feedback. :)
First of all, i seriously doubt you can run the E6750 at 1.35v at 3,6ghz. I bet you'd have to up it to atleast 1.45v. I have the same cpu and i need 1.55v to be 100% stable on this board.
Also, memory is very touchy about running past 1066 on this system when using more than 1 module,- especially when using more than 2. I'd try 5-7-7-24 and up DDR voltage to 2.25
Get OCCT. If you can go past 2 hours in it without crashing you're most likely stable.
I have those exact sticks, and they will be unstable on stock settings, even if you set TRD manually,- atleast on my board.
The only way i could get these sticks stable was with 4-7-7-24 TRD:9 at 1:1 (450mhz/900mhz ddr2) 2.25v
Any other setting ive tried (and ive tried them all at this point) will result in OCCT crashing after anything between 1 second and about 25 minutes.
Funny part is i can use performance enhance: turbo at the settings mentioned above without any loss of stability.
Stable in my book is OCCT running at ram+cpu for 8+ hours.
Thanks for your reply :)
1.45v?! man, isn't that too high? Before changing memory I was running it at 3200Mhz with 1.28v and it was stable with gaming and everything... I never thought this CPU would need that many voltage with OC... :/
my sticks are the blue G.Skills (stock 1000Mhz 5-5-5-15). You don't think they can run 1080 with the stock timings? maybe just upping the tRAS to 18 will do it?
I will try OCCT. Thanks!
EDIT: and I'm running with two 2Gb modules.
e6750 is 1.35 at default 2,66ghz. Ive run it for a long time on 1.6v at 3.8 no problemo. As long as your cores are below 75C you should be fine. (these are bios settings, 1.6v would usually be 1.55v in OS under load cause of the bad droop).
With memory i guess its just trial and error. All hardware is different,- its all a big lottery. Just set up some decent setup and see how it fares in OCCT. If you crash within 30 minutes you need to either slack off settings or increase voltage and try again.
hi
just installed my ninja plus revision B on x38-dq6.
ive up'd to:
3.2ghz (q6600)
1066mhz dom pc800 ram at
400fsb (2.66d)
its running around 52 deg c ( via core temp .95.4)
before on stock at 2.8ghz (which is lower) i was at around 60 degrees on load
running prime.So pretty great because also i have my case fan turned down at the moment. :)
Not all the cores were the same temp on stock cooling , core 3 was averaging '5' degrees cooler always. i thought perhaps the cooler needed laping?
now core 1 is averaging 3 degrees lower so a bit better.
i may re- lap the cooler or even lap the cpu at some time ..But, as they aint broke im not gonna try and fix at the moment,
thanks to shanks for the advice !!
peace:)
freqz
gar look what dfi can do with 4 sticks:eek:
i know not verry good but its only first bios
can do 1200+ but need 2.3v :(
On Air cooling :)
I think I'll drop a little the frequencyes ... Too hot :) I think I reached the maximum of that CPU on air... The voltage I set in bios is 1.65
I'm impressed. Look at my results, I guess I have to optimize my cooling system. Set the same voltage as you in Bios, 1.65. CPU-Z says it's a DQ6, but it's a DS5. Will try to go a little higher, but I doubt the Mem will handle it.
Attachment 69097
New Bios F7H:
http://rapidshare.com/files/77686852/x38dq6.f7h.html
F7H solved sata problems :)
Memory set to tighter timings ... so it's not so overclockable like in the older bios versions.
'Little more. Must say this is a NO fan (@all) watercooling system. (Fans: hate them. Turning, squealing, blowing, gasping, getting dirty :) ).
http://192.168.2.169:80/OPEN4ALL/3640.jpg
BTW, these are the temps 2 secs after quitting Orthos:
http://192.168.2.169:80/OPEN4ALL/IDLE_TEMPS.jpg
post the pics again :)
If a fan fails there is no risk in burning something, if one of the pipes breaks what happens ? :confused:
Got my X38T-DQ6 toady and its Rev 1.1. :)
to bad my QX9650 and ram is still on its way.
