another random question: a single service of XWD be able to manage 2x and 4x installs of D2OL on the same rig, or do you need one service for each instance of D2OL? I'm thinking one should be able to handle everything, but i wanna make sure.
1 XWD installer will monitor single, 2X, and 4X services if they were created with my installers.Quote:
Originally Posted by trakslacker
What if they weren't?
I'm asking for a friend(im way too poor to afford dual-core goodness ;)), but I'm not exactly sure how he went about installing both instances.
Have him check the "services" section in the management console to see if the names are XS_D2OL1, XS_D2OL2, XS_D2OL3, or XS_D2OL4.
I'm pretty sure they have to have them names... maybe the Xtreme creator can validate this. ???
Yeah IIRC dem's da service names. :D
Hey can anyone tell if/how I would put the services for d2olprogress in the config to get them knocked down to lower priority? :shrug:
(Last services in teh list (@ bottom )
Originally Posted by Rodzilla
Add "JAVA=IDLE" to the processes section of the settings.iniQuote:
Originally Posted by mad mikee
Code:##---------------PRIORITIES---------------##
# NORMAL,IDLE,BELOWNORMAL,ABOVENORMAL,HIGH
[General]
INTERVAL=5
[PROCESSES]
DOCKWIN=IDLE
GridWin=IDLE
D2OL=IDLE
JAVA=IDLE
[SERVICES]
CHECK=TRUE
ATTEMPTS=15
The feature to set the process/thread priorities to low will work for both a regular install of D2OL or if D2OL is installed as a service. Also it doesn't matter how many instances are running it will set them all to low.Quote:
The feature to restart the services when dockwin.exe or gridwin.exe crash depends on the names used in Rod's installer, XS_D2OLX, for both the service name and the base folder the exes are located in. Also again one instance of XWD will monitor all instances of D2OL.
i am trying to sue the 2 agnet installer with service suport but i reached the window which says
"attempting to launch XS_D2OL2 Agent for reg ur node "
and nothing else happens
i pressed enter it says " the system can't find the patch "
how can i solve this ?
ok i tried running the Agents by myself and it is working now, i rebooted my pc and i can see in the task manager 2 nodes running
now how can i watch them using this WatchDog ???
how to set the options ?
or i don't need/can to do anything like that , while they r running as services
Download link seems broken.
Originally Posted by SaFrOuT
i'm also searching for the installer?
anyone??
me too ... anyone ??
That could be a problem... Since our team-page (set up by Rodzilla) has been offline for a long time now, I've been searching for the installers myself... I lost mine when the USBstick they were on got corrupted:(
I have been able to obtain some older installers from Jeff (big thanks to him) but those do not include the Xtreme Watchdog but the older D²OLDaddy stuff, which isn't half as good as the Watchdog.
I sent a PM to Helheim a few days ago to ask him if by any chance he still had the original Rodzilla installers with the Watchdog included, but haven't received an answer yet... I'll try to contact him again ;)
wicked .. i think we will be waiting for that answer ... but i have to get some more rigs to crunch some points .. i´m still running low .. but still i am helping :P
You sure the site is down? Everytime I click on this thread I get a box requesting a username and pw for Rod's site... Something is working. :)
-SS
I fixed the pop up. It was from Rodzilla's sig..
I've hosted the installer files in this thread here...
