Great, now i have a good reason to upgrade to amd64, now that the prices dropped on the 3200+ im gonna get this mobo and the 3200+ newcastle- weee
:slobber: :slobber: :slobber:
WHAT BOARD?Quote:
Originally posted by OPPAINTER
I'll run some tomorrow, right now I hooked up a 939 mobo.
Just got a new FX-53 I'm testing.
OPP:D
WHAT RAM?
WHAT VOLTAGE??
oh my god ... show us more :slobber: :slobber: :slobber: :D :DQuote:
OPP:D
That BIOS is gonna put me out of a job :DQuote:
Originally posted by bigtoe
Bios pics
<snip pics>
So now you know what to expect, there may be more tweaks in the next bios which i haven't recieved yet..i will update.
Tras of 0 is really 5 clocks ;)
Well I thought that but 5 showed some instability, so maybe there are other tweaks along the way. I fully expect most of the options this bios has will disapear on the shipping bios though.
Its nice to show for giggles though..LOL
I think its great that the BIOS writers started making ALL the options available to the users. They'll probably have to limit the ranges to those officially supported (and documented) by AMD though.Quote:
Does the BIOS has all the CAS Latency values avaiable? If so could you do me a small favour and dump the DRAM controller registers using WPCREDIT (bus 0, device 24, function 2) with CAS Lat set to 1.5 clocks. I have two possible decoding schemes for the reserved CAS values ... just need to double check.
I am also curious about the drive strength setting. AMD docs show only two possible values:
0 - Normal (default)
1 - weak (beware) <--- exact words out the AMD doco :)
Ive tried "weak" and it was very very bad, so I left it out of A64 Tweaker. Maybe there are some more controls in the reserved fields ;)
Cas 1.5
2
2.5
3
all work it seems
all others crash the system.
I will try and have a look at the registers for you.
What Happens when you stick a mobile A64 chip in? :confused:
This question is for all of us who want a DFI and a 35w A64 3200 mobile WITHOUT having to buy a desktop chip to boot with first!?!?!? :mad: :upset:
Good results in answer to this question will open the floodgates even further :toast: :banana: :banana: :rocker:
wow i want this without even trying my kv8 pro yet
ABiT is crying right now :p:Quote:
I bet it would work flawlessly (thats why Oskar gives Vid control as an option ;) definitely outstanding job. :DQuote:
That board is crazy, DFI will win again...
what about VCore-drops and fluctuations.....the DFI nF2 Infinity is ja very good board as well, but in that thing its the last crap on earth.....i love my board and i hate it at the same time....
Due to the fact that they have upped the max vcore to 2.1v, where the most seen before on other boards is 1.7-1.85v, I think they paid special attention to the NF2s vcore problem, and fixed it on this board accordingly ;)
But that's only a guess :)
I don't get a v-core drop. The voltage actually goes up around .05 under load.Quote:
OPP
Any idea how much longer we have to wait for the retail version release? :drool: Also, will it support Mobiles right off the bat?
aahh, very good :)Quote:
OPP
Well...400HTT anyone ;)...I have a feeling it will do a lot higher also.
http://www.xtremesystems.org/forums/...chmentid=14857
wowoww, what are you runnin your ram at?
Well the max i could get was 425HTT at the 4 multi which doesn't seem all wacko on this board.The ram is running 140 mode so ddr600 or so but this is not a good divider for memory bandwidth.
Just a HTT screenie for jollies.
http://www.xtremesystems.org/forums/...chmentid=14869
jesus....
thats insane.
I can't wait for DFI to finally release this board.
whats the world record for HTT speed? is it higher than that?
Man, I think yours is the record:toast:Quote:
All I could find was this 400 shot.
http://www.xtremesystems.org/forums/...010#post332010
OPP
this is one SICK, NASTY motherboard! DFI is :owned: ALL!!
C
