Originally Posted by
NEOAethyr
I got the iso yesterday but haven't burned and installed it yet (let a buddy borrow my usb stick).
I do agree that it installs fast.
But I don't agree on the quick startup, it seems like a bit slower startup to me.
Just that it takes 100% of it's startup time exe'ing the boot manager, at which point the os is already fully loaded up.
Also, this essentially double's/triples startup times for win7 if you have it installed to the side, 'cause 1st you must startup win8, then it restarts the pc into win7.
WinME lol...
Everyone hates that os except me.
I liked it.
Yeah it had a 1 major issue.
If you del'ed all the defaults under the 2 run key's, HKCU/HKLM, then 100% of the probs went away.
It was such a simple tweak too.
I liked it because it was slightly more up to date then 2k, also I did not like win98.
I used use win95 even though I had win98 at the time, once winme came out I switched to it.
It's wasn't quite as quick as win95, being that it took up more ram and such.
But it's hd speeds are leaps and bounds ahead, I think it was a program called neoragex or something, in some sort of emu, the hd speed, loading and decompressing large roms was way quicker.
Plus it was much more up to date then win95, which at the time, was a pain in the butt to setup and update all the way at that time.
I never did get my hands on neptune, the very last win9x os, which was dumped 1/4 or 1/2 of the way through dev'ing it, and focus was made on xp.
I may switch back to win2k3.
If I can get dx11 working 100% in it, I will switch back.
Apparently the xp patch for that has been worked on lots since the original back in the day.
The idea is this, if dx11 can be ported 100%, then all I would need doing is to redo the taskbar to show a small preview screen of the task when hovering over it, via ahk script :).
Btw, win7 uses not dx10/11 for it's dwm, but dx9 lol, not sure about win8 though, never checked it.
Anyways I'm gonna install win8 rp either tonight or tomorrow and see if the speed has improved or not.
