hey bro !!! back to OC ?
i will see as i did flash with ROG (the usb at the back) and same thing dont work :(
Here is my current OC while folding@home. It was suggested to me in another forum I should be able to push more if I enable LLC 2 and perhaps 1.9v to the PLL volts?
http://img151.imageshack.us/img151/5...ghzfolding.jpg
Uploaded with ImageShack.us
It was settings, 2800 bootable, just need a good kit to play with now.
3570K batch# 3208C060
1.253V under load on NH-D14. Ambient temp ~23C. Load temps got up to 90C on the hottest core using RealTemp
Attachment 126393
Ok guys some old school vintage P67 action!
3770k L206B314 P95 x64 stability testing on an Asus P8P67 Vanilla Bios 3207, air-cooled on a Venomous-X with 2x Enermax Magma 120mm fans:
4.7ghz @ 1.328v: ouch, kinda getting a little too toasty so stopped after 30min:
http://i246.photobucket.com/albums/g...0kp6747ghz.jpg
4.6ghz @ 1.276v after 1 hr: idles at .96v and 1600mhz - not too hot and not too slow - this is going to be my Goldilocks setting :)
http://i246.photobucket.com/albums/g...0kp6746ghz.jpg
ned help whit 46x108
it restarts my gfx driver all the time in 2d,is there a voltset I can put in.to order to stop it
to oc nub
wprime
Attachment 126403
I see many voltage & temp jump at 4.8 or above for IVY
Gotta admit have been quite impressed with ivybridge. Just bought a 3770K with a Gigabyte GA-Z77X-D3H and am currently running 3.8Ghz with 0.988v stable using stock heatsink. I will start pushing it when my new w/Block comes.
4.0Ghz 1.055Vcore on stock heatsink Batch3213B440
http://i19.photobucket.com/albums/b1...Untitled-1.jpg
I'm thinking it might be my motherboard holding me back.
i7 3770K L206B351
ASUS P8P67 Deluxe BIOS 3207
2 x 4GB Samsung HCH9 @ DDR3-2200 9-10-10-28-1T 1.55V
Noctua NH-D14 stock fans @ 5V
43x100 @ 1.176V (offset of -0.010V) in BIOS, LLC on Ultra High, everything else on auto
44x and higher result in a BSOD unless I push 1.275V+
Stability with the RAM overclock, as well as the lower power draw is what drew me to Ivy.
I have a P8Z77-V Pro on order that will hopefully work more nicely with the chip.
http://www.zhoulander.com/projects/ivy/3770K-4300.png
3570K #L202B743
in my attemp to figure my best bclk (so far it settled @102-104mhz)
3.977ghz @1.064v
hsf : NH-D14 (default fan on hot tropical summer :D w/o ac too :D)
Attachment 126426
[spoiler]
Attachment 126427
[/spoiler]
i am still trying to enter "4.5 club" w/ vcc (around) 1.1v and still... haven't got any luck:shrug: :shakes: :rolleyes: i wish i had more time and (luck too) :ROTF:
btw, i wonder if i using wrong version of ibt?? why it got "low'" speed output ~58gflops
yesterday i belive i have d/l the latest ver (v2.53)... can anybody enlighten me.
Batch# L209C112
http://i46.tinypic.com/2rggduh.png
http://i48.tinypic.com/szif78.png
MOBO: ASUS MAXIMUS GENE V
CPU: i5-3570K @4,7ghz (1,25 vcore) (cooled by Thermalright Ultra 120 Extreme)
RAM: Corsair Dominator GT DDR3 (2x2GB) @2200Mhz (8-8-6)
SSD: OCZ Vertex 3 120 GB
VGA: Gigabyte GTX 680
PSU: Zalman ZM850-HP
i7 3770K L206B351
ASUS P8Z77-V Pro 0906
2 x 4GB Samsung HCH9 @ DDR3-2133 9-10-10-28-1T 1.55V
Thermalright HR-02 Macho
45x100 @ offset of +0.005V (or whatever is the lowest setting is) in BIOS, CPU PLL @ 1.6V, LLC on Ultra High, everything else on auto
The NH-D14 doesn't mount with as much pressure as the HR-02 it seems. Also, setting Internal PLL overvolt helps immensely with Ivy clocking, whereas I never needed it on my SB 2600K and 2700K even up to 48x multi.
http://www.zhoulander.com/projects/ivy/3770K-4500.png
these memory speeds on the IVY are crazy!
These Ivy chips are crazy!! There's got to be something missing right? Internal PLL overvoltage or something.
4.5GHz IBT Stable @ 1.14v
5.0GHz 32M Stable @ 1.32v
5.2GHz 32M Stable @ 1.525v
5.3GHz needs 1.65v just to run!!!!
http://i106.photobucket.com/albums/m...70K520032M.png
Bet the temps were off the chart at those voltages.????
