What default clocks are they?
ok.
i flashed my msi stock card with evga sc+ bios
my clock under heavy 3d session is now 1189mhz (with stock bios are 1089mhz)
but i need to raise gpu power to maintain tath clock stable.
great bios!
http://gpuz.techpowerup.com/12/04/06/87v.png
That must be the issue, because you run sli and 3D. With this Bios, I can run Battlefield 3, crysis 2, with ultra settings, without raising power target. 100% stable, on single card and no 3D.
I get the same boost on my card that you have.
This is a fantastic card for Battlefield 3, for me its even better then gtx 580 sli. OK you got more frames, but much more stuttering.
Fantastic, 249 points to beat the world record at futuremark benchmark ticker
Thank you buddy!
I got a great evga 1324mhz aircooled.
First test with water, hope to increase clocks later:
http://tof.canardpc.com/preview2/211...af715d005a.jpg
Is there an XP 32 bit driver to be had for these cards? Expecting UPS with mine any minute. :D
Need XP to see how 3DMark '01 is with these cards. ;)
Guys, a few questions:
1. do you think the varying turbo clock is a way of picking out better binned cores? Maybe indicating which will have a better max clock?
2. Why do you think water cooling does not increase maxclocks at all (unlike nearly every gpu made before 680)?
3. What do you think limits max clocks on these? Mine could only do 1058+180=1238 with much room left on the vgpu slider, more volts didn't help, so what is holding it back?
4. Other than kingpins record holding vid card (record number of mods needed to run LN also lol) has anyone else tried hard vmod to over ride built-in throttling measures?
5. Is there any trend in brand etc when we look at which models clock best? What brands are hitting 1300+? Or is it random across all brands?
6. What is the highest clocking example (non-LN cooled) that you guys have seen?
Since these max out with only a small bump in vcore I feel there is something left to unlock, a mod to find that will unleash these when combined with better cooling, what do you think?
I bought one on release day for $700 (yes that's how much they were here), I benched it and awed at its power then sold it quick while prices were still up and stocks were low. When prices get closer to RRP I will buy two again.
:D
i wish there was some way to unlock more power. what i read is that you can short one of the connections on the VRM chip and it will let you set vids higher than the 1.175v, but then you need a bios with those vids in there. but were already talking about completely voiding warranties, and who knows how much power the vrm section can provide before they pop. its a shame they went so cheap on the board itself, the chip is really impressive.
1258 max, not great but enough to smash my PBs, I sold it because I knew it was well above RRP so prices will settle a lot when more stock is available. I think I will wait for some of the beefier non-ref PCBs to come out, like the Zotac Extreme that has just surfaced.
:D
