very nice Nizzen!
The Areca 1880ix-12 i got quoted AUD$1155 for it = US$1033 :eek:
very nice Nizzen!
168743 hdd suite with only 1gb cache (not 4) - i take back what i said in the other thread - this might be significant.
umm yes. here is ram specifics fellas...they pointed me at two different sets of ram:
the spec they attached is this model number: KingstonQuote:
Hi,
You can select the attachment spec.
You can also use the following DIMM which has tested on our side.
Unigen memory module UG51T7200N8DR-8CC. it is DDR2-800 4GB ECC reg.
Regards
Billion Wu
KVR800D2D8P6/4G
4GB 512M x 72-Bit DDR2-800
CL6 Registered w/Parity 240-Pin DIMM
the second seems easier to find. i have yet to find aplace where the unigen is for sale.
@nizzen that 4k @QD1 is exactly what i have been looking for, amazing!
taking a day off work thursday for this one......
@doublepost....now that i have the spec on the kingston i ordered this from an online retailer, but it seems that it doesn't match the specs of what the pdf shows....any ideas fellas? it shows that it is a 9 chip config on the PDF, yet in the picture from the site i bought it at there are many more chips, confusing.
the spec in the PDF states: eighteen 256M x 8-bit DDR2-800 SDRAM in FBGA packages
yet in the one i bought it is listed as: 36c 256x4 Registered ECC DDR2-800 DIMM.
I am wondering if the 256x8 vs. 256x4 will make a difference?
http://www.memoryx.net/bvj.html
can anyone find a solid link to something that looks like the pdf file? i am wondering if the chip i have purchased is listed incorrectly....
cache? but then that would be affecting the sequential as well...I know that tilt with his 9260 on a server mobo was getting .05 access time, seen it with my own eyes via msn video chat.
One_Hertz,
That's why we need some iometer testing, AS SSD isn't perfect.
Nizzen posted a quick iometer run at the Norwegian forum, single C300 128GB -> 4KB QD64 ~73' iops, testfile 1GB (same as cache)
WOW!!! :eek:
In germany only 625€ or US-$ 793 <- klick (translated)
Mr Fear - long time no see bud!
I've just browsed the iometer result file from Nizzen, random read 512B-128KB QD1-64 exp2
It looks great, a few disturbing drops in performance at high QD on some block sizes.
I'm not sure what drives he's been using, how many drives or the size of the testfile. (I expect 1GB testfile)
Access time 0.02 4KB QD1
Well, it's up to Nizzen to make this publicly available, it's well past midnight here so I expect it will be tomorrow.
I expect some graphs would be of interest :)
yes the graphs would be very interesting....
I asked the question if a sata only version would be made to replace the 1231 controller.....
so they, like others, will no longer make sata only cards. interesting. as i have been saying for a long time, the latency issues with sas/sata protocol tunneling have been overcome.Quote:
Hi,
No, ARC-1880ix can support 6Gb/s SATA and SAS.
You can use the ARC-1880ix-12 to replace ARC-1231Ml.
Regards
Billion Wu
Come on @ Nizzen :D
Is it even worth it to get anything with more ports than the ARC-1880-ix-12 with SAS expanders so prevalent now?
August 27th these should drop?
How many users are using a 1880?
1880 + Samsung F3 EcoGreen 2TB good or bad?
Not that many yet.
That will change during the next few weeks.
Don't know about the Samsung EcoGreen, Samsung drives usually work on raid controllers from what I've heard.
I've got 4x F3s running on a PERC 6/i, no issues yet.
I was told that I was the first in the world who got the Areca 1880 :D
The serial numbers who came to Europe was from nr one LOL
Looks like I am the only one for now that have the 1880. Anvil is coming right behind me. He is getting a 1880ix-16 on maybe friday :)
Does the Areca 1880 support to display CPU(Controller) temperature and HDD SMART status?
If Fedex lives up to their tracking i should have mine within the hour, have the 4gb of ram here waiting...
So I am torn between the 1880ix-12 and 1880ix-16, I read somewhere that Areca uses "less" than stellar SAS expanders on board (avs forum?) and its best to get as few ports as possible and rely on HP sas expanders or similar. But really is there a reason to get more than the 12 port with SAS expanders so readily available?
