pwease explain?
I thought "CMT" "SMT" (!?) was intragral to the design of the Ccore/"Module"
pwease explain?
CMT is not the same as SMT. Bulldozer IS Clustered Multithreaded design,each module(or "super" core) is composed of shared and discrete structures inside(shared front end,L2,shared FPU with a method similar to intel's SMT,discrete integer cores with discrete L1 caches).While BD cores share some parts and have dedicated execution units per core/thread inside the super core/module,intel's Westmere/SB cores dynamically share resources within single core(entire pipeline).It is speculated that one BD module will be smaller than one SB core but will have greater throughput.
Sure that's how I understand it. You say Bulldozer will have no SMT in version 1.. So looking at it the other way, what will the next revision have then?
Well it is 8 cores/8threads now,but AMD didn't say they won't bring SMT at some point in the future. Version 2 may have it(SMT,each integer mini core being 2 threads capable) and may have eager execution wrongly called "reverse HT" (done entirely by hardware and assisted by software). Also there could be a GPU in the place of the FPU we see in Version 1 :).
Ah OK thanks. For a minute i thought they'd chopped a BD module in half or something ;) . Sounds interesting, as does the upcoming fight between It and SB
Yeah it will indeed be interesting clash :). Launches won't happen at the same time,but 2011 will see both designs on the market.I'd say server will be a win for AMD,while desktop a slight advantage for intel(depending on the clocks too).
I think Llano socket is to small for highend Bulldozers.
who knows.
Llano = 4 32nm K10 cores + GPU.
Bulldozer = 8 BD cores. I think they can use the same socket, the gpu in llano should be quite a big part of llano.
Exactly, especially since the Llano socket can be made with BD support in mind.
The AM socket series have no PCIe or IGP support, so to me looks like a dead end.
So why not use the same socket for both Llano and the next BD?
Do you know how big it is? I haven't seen it.Quote:
Unless they thought of that too.:yepp:
AMD probably learned a lot from the AM series, so they must have thought twice before finalizing the new socket,
and remember to include whatever they might want in the future, even if it's just represented by reserved pins for now.
Again, that is, if they want to use only one desktop socket.
bulldozer will have quad channel that's already known.
Yeah they must include it,maybe as a part of the new GPU?
