anyone help me with this issue??
i found before this volt mod, i could get around 690 core/ 1100mem clocks...now at 1.163v i can get around 715core and 1150mem....can i cut of a further resistor under air cooling?? without causing damage getting around 72 under load in 3dmark vantage atm....or should i wait till i get another waterblock for my second card
Sorry for my offtopic question,
I have always been fascinated by voltage mods buy I want to learn more about them, not just only have the schematics and do the mods. I want to learn how to do them myself...
How did you get started to vmods?
Who me :)
for me it was the need for faster gpu clocks
and many years of tinkering with soldering only recentlly i have adoppted it to pc's :)
volt mods are easy
threads like this one are very encouging
most mods can be found on the web just google xxx volt mod (x = card)
Thank you for the reply, but I didn't asked that:P
I wanted to know how to come up with the vmods not just finding them
easyist way is from 4qman's guide
http://www.benchtec.co.uk/forums/showthread.php?t=992
What is the highest I can safely run my memory on stock cooling? I have had a couple 295 boards fry or burn out on my when I pushed the memory to 1250. I assume it is because that giant heat sink up top is the heat sink for the ram and the NIVO/SLI/PCIE bus chips, as well as the mosfets and regulators?
Gerret, Can you please help me with this Mod. I is it simply soldering wires from one end of the line to the other. What are the pink and green short lines supposed to indicate. Also what is the 10 ohm VR supposed to indicate. Some detail instructions for newbies would be fine. I can use a solder but I'm very weak in electricity. Thanks
