Originally Posted by
Vapor
Okay, finally did the math with real PQ curves....let's throw out a few fun examples of just what the T3 can do :p:
Let's take a sample loop of the Aqua Computers Double Impact, two MCW-60s, and two HWLabs GTX480s. Two of the most restrictive rads, a very restrictive CPU block, and two standard GPU blocks. Not only that, but I'm quite sure the ACDI is one of the more pump-hungry blocks out there (that doesn't mean most restrictive, that means an increase in flowrate does the most for its performance!).
In a normal serial config, this setup will get .89GPM. With the Typhoon III, splitting the ACDI into its own subloop, Subloop A, and everything else into Subloop B, you get 1.34GPM through A and .98GPM through B!
To put that in perspective, two D5s in serial (with the rest of the setup in serial) only gets 1.30GPM!
Another possible config: Apogee GTZ, 2xMCR320, and a single MCW-60 (yes, an all-Swiftech config). All in serial: 1.39GPM. Split up with just the GTZ in Subloop A: 1.79GPM-A and 1.66GPM-B.
Adding another MCW-60 to Subloop B drops serial flow to 1.30GPM, raises Subloop A to 1.85GPM and lowers (without any drop in performance) Subloop B to 1.49GPM. Again, the GTZ is a block that LOVES flow, so the Typhoon III is helping performance quite a bit here :)
Not only is the CPU block getting a significant boost in flow with these configs, but the secondary components are also getting a slight increase. :D
EDIT: bluehaze, it is possible to have different (controlled) flowrates in different parts of the loop. Just use a shared Reservoir with multiple subloops with their own pump(s).
