Very unique, love the colors.
It's awesome. Nice work subset! :cool:
Love the LCD's and the optical bay. Looks great!
Hi, nice work indeed.
Can you tell me what you think about those Enermax fan ? I what thinking about getting some. Are they good (noise and air flow) ?
Thanks aka_GK,I hope to get them done at the weekend :)
Thanks Liderc :)
Thanks Bill :up:
Thanks XKaan,I'm pleased with the way the front turned out aswell :)
Thanks Cedric,They're audable turned up full,but by no means annoying,so noise wise i'd recommend them and they do seem to shift quite a bit of air,BTW I like the way your build has started,looking forward to it :)
Cool, I'll probably get some then. Hard to find decent white fan out there :xQuote:
Originally Posted by subset7
And thanks, its hard work to do all this stuff :D
The colouring looks a bit too clinical for me but I can 100% appreciate the workmanship that has gone into it. Your attention to detail is awesome :up:
I think the White looks very refreshing. White is the new Black! :)
Thanks for the comments guys they are appreciated,I just got back from holiday so need to sort out some finished pics,also it's been nominated for Mod of the Month over at bit-tech
http://forums.bit-tech.net/showthread.php?t=176221
Any votes will be welcome :)
looking good :)
btw, you dont have to cut anything to open up the lcd displays...u can push the bits in and pop them open.
I tried that first but they were so tight I didn't want to damage the PCB inside so cutting them seemed the easiest option.
I have the same one and it just popped open? :s
Subset- do you have any details on how you soldered/connected the water temp thermistors to the LCD readout displays? Which make/model of them did you use (the temp probes)? Did you have to worry at all about the water temp thermistors having a different constant or coefficient or whatever it is that allows the meter (LCD) to calculate the temperature? I might be thinking about trying this on my new build and just wondering how you got it to work. Thanks!
Sorry for the late reply Ketzer,I used These XSPC displays,and These temperature probes,I just cut the existing probes off the displays and the connector off the sensors and soldered the wires together and covered the join with shrink wrap before sleeving them,I tested them outside the case first and only got a 0.2 degree difference,so I was happy with that
http://i296.photobucket.com/albums/m...1124Medium.jpg
Good Luck with the Mod of the Month @ bit-tech!
Thanks shazza&CptDreadFlint :)
I finally got round to taking some finished pics,thanks for being patient and thanks again to Bill Owen and MNPCTech for sponsoring me with his awesome 120mm Machined Billet Computer Fan Grills:),anyway here it is.
http://i296.photobucket.com/albums/m...8840Medium.jpg
http://i296.photobucket.com/albums/m...1363Medium.jpg
http://i296.photobucket.com/albums/m...1350Medium.jpg
http://i296.photobucket.com/albums/m...1324Medium.jpg
http://i296.photobucket.com/albums/m...1609Medium.jpg
http://i296.photobucket.com/albums/m...1611Medium.jpg
http://i296.photobucket.com/albums/m...1535Medium.jpg
http://i296.photobucket.com/albums/m...1541Medium.jpg
http://i296.photobucket.com/albums/m...1545Medium.jpg
http://i296.photobucket.com/albums/m...1582Medium.jpg
http://i296.photobucket.com/albums/m...1591Medium.jpg
http://i296.photobucket.com/albums/m...1559Medium.jpg
http://i296.photobucket.com/albums/m...1247Medium.jpg
http://i296.photobucket.com/albums/m...1612Medium.jpg
http://i296.photobucket.com/albums/m...1607Medium.jpg
Forgot to mention,for the lighting I used a combination of bright white and UV CCFL's and LED's :)
Excellent photos - this really turned out to be an awesome build. That fan grill definitely compliments the overall look.
PURE beauty!
subset7 amazing work, love the interior, love the exterior :)
PURE awe!, shes a beaut :)
Beautiful work.
Just... amazing. Your pictures combined with the lighting is pure magic :P
Thanks shazza,i'm really pleased with the fan grills :)
Thanks illidan :)
Thanks Bill :toast:
Thanks Liderc :)
Thanks Viking,I spent ages with the lighting trying to get it the way I wanted it :)
Subset, thanks for the info. Not too loong after I posted that I actually got pointed to a tutorial type article on OCAU that did the same thing as you with the XSPC temp sensors. So thanks for confirming that bit!
And BTW, I would be remiss not compliment you on the excellent work of your project. Kudos.
i been thinking about doing a white case. After seeing your, you motivated me into doing it. Awesome work!
