PhenomMsrTweaker: Cool and Quiet customized
A utility to completely customize the Cool & Quiet feature of AMD K10 (Phenom etc.) processors. It may be used to overclock and/or undervolt the CPU. Its primary aim is to allow on-demand use of the powersaving Cool & Quiet feature even when running the CPU above its original speed.
PhenomMsrTweaker allows to fully customize two CPU performance states: multiplicator (per core), Vcore (CPU VID) and integrated Northbridge voltage (NB VID) of P-states 0 (performance) and 1 (powersaving).
Additionally, it provides a customizable replacement for the standard implementation of Cool & Quiet in the Windows driver and allows to control standard or custom Cool & Quiet via on-the-fly power scheme switching.
http://phenommsrtweake.sourceforge.net/Screenshot1.png
Any "slow down" issues with PhenomMsrTweaker?
I read that AMD Cool n' Quiet has an issue in that it doesn't give you the maximum performance when you need it, i.e., when the load is high. For that reason it has been called "Cool n' Slow". So this article is recommending to use RMClock instead. Are there any such "slow down" issues with PhenomMsrTweaker? And how does PhenomMsrTweaker compare with RMClock?
Thanks! :)
