Same as all X58. Uncore must be at least twice of RAM frequency. 1000Mhz = DDR2000 = NB 4000
You just can't choose anything else because 4Ghz Uncore under water is quite hard. So more is difficult, less is impossible :yepp:
took a lot of head scratching for me to figure that out but i got the hang of it on my second session heh
God I wish I had the time and equipment just to prove everything wrong :(
First time going on XS for like 2 weeks.......
I will donate a weekend in January to sort out fact/myths on this one.....
nb, yes, but you said qpi :D
1.65v is fine afaik, 2v is... not good ^^
:lol:
yeah was thinking the same :D
you know what mark, in your own way, you really are an XS legend ^^
I hereby nominate you as Xtremely Special Legend :D
wow, nice self reflection there, there is yet hope for you! :toast:
take it easy on me
i'm still a nehalem noob
gigabyte guys told me that some of theissues i was having are bios related and the new F4F fixes some uncore problems lol so will load that up next
next i am testing RAM and superpi
gotta see what its all about
Man this saddens me. I7 is taking the bandwidth fun out of life. I mean I love running high volts just because of the potential it gives.
well i think it was a freak accident actually and high vdimm is safe, maybe even with stock vtt... so far i think only B stepping chips died from vdimm, C stepping seems to be very robust in regards to vdimm...
That's what I thought. The above post now makes me glad I've stayed in spec with the RAM. I figured that was gonna happen, and it's unfortunate. SOmething tells me as time goes on there may be more. We can't tell whether they will degrade over time. I'm sticking with 1.65v. With the Bandwidth this thing has I can't see any reason to go above that.
The highest I've run my vDIMM was only 1.8V (and +0.25 VTT...1.45V right?), and I've only been testing for about a week. But two days ago, I lost one of my mem channels...now BIOS only sees 2 of my three DIMMS. I'm pretty bummed, but I think I'll back off the voltage a bit.
What board you use miahallen ?
MSI Eclipse SLI...wouldn't have been my first choice, but I needed to do some homework for the THG Competition in Paris on Dec 13th & 14th...Team IORNMODS is representing as Team USA. Unfortunately, looks like my time to do homework has come to an end. I lost a second memory channel today. And the setup is quite unstable in single channel mode, even with stock clocks....I hope I learned enough to represent in Paris. :shakes:
I think when this is over, I'll have to get the P6T or a GB ;)
Sorry to hear, have fun in Paris, awesome city :up:
Saaya, so wich are concidered to be "safe" voltages for D9JNL chips with nehalem?
I´m using 1.8vDimm and 1.35V QPI with GA-EX58-UD5 right now
This is my best bandwith shot:
http://www.aijaa.com/v.php?i=3202172.jpg
That sound very "strange" to me, the catastrophics diode protections are stopping any heat crazy stuff, and I never saw in our lab a test of transistor dieing so fast ... you are doing something very wrong. Did you modify your board or something like this? With enough cooling, I never saw the life so short.
Do you still have the processor that you claimed are dead? I am interested in getting them for analysis, since we never saw that kind of extreme death.
Francois
I have ran my C0 revision (I think it is) 965 with patriot memory at 1.9v and stock Vtt through prime95 for 24hrs and through 10 days general use before the actual memory started to fail and refused to post.
Now I am running Mushkin 2x6Gb kits at 1.64v at 1333mhz because the latest bios update refuses to allow speeds of 1600mhz
1,65Vdimm seems very low for me ;(
How could you for example run these Rams : http://www.com-discount.de/FMPro?-DB...=ALL&-FINDALL=
They need 1,8-1,9Vdimm to get these clocks.
But this would be impossible according to your post if you risk damage after raising Vdimm above 1,65..
Guys (especially Francois ;) ),
do you think it is (fairly..) safe to run 1,8-1,9V Vdimm 24/7 if I am on phase? -30C evap so CPU should be zub zero at all times...
C0 965 XE. Thanks :)
@Bla$na: I intend to use those exact mems (well.. the 2GB stick version of it) so I'll soon find out ;)
I have been running 2v 24/7 on phase
Nice FUGGER, thanks. Now if you could get back to me on that chilly1 lga1366 holddown (pm) I could try myself :)
