Gas wow nice you sure that 880 core is stable though on stock volts?
I know sniipedogg had to volt mod for that level or around it.
Flashed my Asus HD4870 today. Auto tune gave me 890 core, but I backed that off as I dont want to fry this card.
Here is a Vanatage run.
http://3dxtreme.net/other/Q6600%20L7...edAsus4870.jpg
..and 3dmark06
http://3dxtreme.net/other/Q6600%20L7...870flashed.jpg
GAH i installed asus smart doctor and it overwrite the fan controll from bios and it sux.. even after uninstall smartdoctor i still got smart doctors fan settings.. anyone know how to remove it comletely? i search in regedit for asus but cant find anything.
I had some info that this BIOS acts different on some cards. Difference is in unlocked Overdrive I guess, or we've just got different info from different people.
Some say Overdrive is unlocked to 1100 for memory, and some say 1200 is their limit (after flashing with this BIOS ofcourse). So could you guys check and post which manufacturer/model gets which limits for GPU/mem? Cos' maybe everyone gets 1200, and than we just have wrong info in the first post.. and maybe everyone but few selected get 1200.
Tnx!
@LuxZG , i know for Club3D and Asus it is max 1100 in CCC on memory
can i flash it on commant prompt in windows?
Or how i can go to DOS?
I have P5K and F8 brings up first boot device, not the boot options menu.
sweet Gas sound's to me like asus card's are the ones to get from your results...wouldn't be suprised if you get 950.
GaS does your asus have the same vgpu as the regular cards ?
:up:
It is stock "vanilla" 4870 from Asus, without even game bundle:) So I guess with stock voltage.
Anyone tried it with a Powercolor card?
Yes i have just flashed a powercolor card and i works sweet 900/1100mhz in CCC and asus smart doctor works great
Thanks :up:
I don't think that was his overclock I think he's commenting about the max values available to oc up to.
so most of the peeps here used the atiwinflash or the bootdisc way?
i just :banana::banana::banana::banana:ed up my flash and its 8 am in the morn :) (got owned around 5am)
so i inserted a 8500gt in slot 1 of pci-e
and put the 4870 in slot 2 and system finally booted.
i used the flashway in page2 (winatiflash) , and after the whole bar finished twice , my system freeze on the 3rd time and after i pressed the reset button it was owned :(
now i m tryin to recover it :/
i tried to run winatiflash but it wont run and stays 25% on core 1 , (any other app i run during this wont respond either, would like to hear comments)
Code:Z:\atiflash360>atiflash.exe -i
Exiting due to signal SIGSEGV
General Protection Fault at eip=00035e57
eax=fd750000 ebx=00000000 ecx=fd750000 edx=02990000 esi=00035ad0 edi=00066a0c
ebp=000e48a8 esp=000e4840 program=Z:\ATIFLA~1\ATIFLASH.EXE
cs: sel=01af base=02990000 limit=0042ffff
ds: sel=01b7 base=02990000 limit=0042ffff
es: sel=01b7 base=02990000 limit=0042ffff
fs: sel=017f base=0000dea0 limit=0000ffff
gs: sel=01bf base=00000000 limit=0010ffff
ss: sel=01b7 base=02990000 limit=0042ffff
App stack: [000e6a08..00066a0c] Exceptn stack: [00066920..000649e0]
Call frame traceback EIPs:
0x00035e57
0x0003651b
0x00035af5
0x00023dc8
0x00002592
0x00009314
0x000167a3
0x000169c7
0x0003f74f
i wonder which index is my ati card need some help on it :)Quote:
Then go into DOS and find out which adapter number your dead HD 4870 has using Atiflash (download): atiflash -i. Now flash the BIOS using: atiflash -f -newbios -p [index] 4870.bin. Replace [index] with the number of your graphics card from the -i command.
Everything with atiflash happens in true DOS only, you cannot run/flash using this utility inside Windows.
