He just wants to watch his DirecTV!
definitely needs a fan or something. Fins would just heat up and become passive cooler surely
Well, Duh!
Yeah, I'm also booked up for review sample for http://mato78.com , I will propably test it against IFX-14 and few other coolers like Xigmatek and Noctua products and decent DIY watercooling.
This was posted on Engadget a few days ago with a pic
http://www.engadget.com/2008/07/18/d...10-cpu-cooler/
and
http://www.biosmagazine.co.uk/article.php?id=6143
http://www.blogsmithmedia.com/www.en...amics-lm10.jpg
Although theres no mounting hardware/holes in the picture, i bet fans will be used.
that's not a new pic:p
Danamics to Launch its Liquid Metal LM10 Processor Cooler in November
http://www.techpowerup.com/75119/Dan..._November.html
repost, look a few threads down
Wow Thats hell of a bump
this liquid metal thing sounds promising
anything that characterizes itself as 'revolutionary'...
Tbh the heat conductivity of water is terrible at best. Better than air though, but FAR from any metal.
hey Rob
you got any numbers to show us :D
from what i found, the "liquid" is Galinstan which is an alloy of gallium, indium, and tin.
source; http://en.wikipedia.org/wiki/Galinstan
so the conductivity is 16.5 Wmk for Galinstan and Water is 0.691
source; http://hypertextbook.com/physics/thermal/conduction/
soo this cooler should kick ass.
Any ideas on how much this thing is gonna cost us?
Quite a bit, depending on the turbulence of the liquid. If the conductivity is zeroish, then extreme turbulence is needed for the same results for liquid with good(+100 WmK) conductivity. Though, this issue is minimal ad unnoticeable but under special circumstances it could become an issue. Then again, thats far from average computer water cooling system. :D
To the topic: Danamics - TRUE with EXTRAHYPERVERYGOOD heatpipes, double the price. :down:
I remember lurking on this when it got blasted on Engadget forever and a day ago - if I had price and performance number I am open to looking more at this but I'm not too optimistic on it performing much better than higher end heatpipe coolers
It looks like it's got 5 8mm heatpipes, if that's so and it's got good liquid flowing well around the heatsink, it may work well.
Problem I see with it is how will it be cooled, even water needs a fan and it doesn't look like a fan would would hit but 1 heatpipe.
