what MCH voltage are you using again?
have you tried pushing it a bit more :shrug:
Thank you m8! ;)
I used 1.70VMCH then.
Now I use 1.75-1.77V.
But the situation is not so improved..... :(
I need much trial and time. :D
Thank you for your helpful advice, eva2000-san! :)
I also think key is in GTL ref volts like DFI P35 mobo. :p:
I will search and try GTL mod for P5K. :up:
Then I have a bit improvement of pifast.
I used before-san's setting. :D
Thank you so much for your advice, before-san! :up:
hexus_pifast : 16.03s @5853.9MHz (FSB616.2MHz x 9.5)
http://homepage2.nifty.com/NewBeetle...fast_16s03.png
This is an illusion that exists in my mind. :p: :D
http://homepage2.nifty.com/NewBeetle..._15s97_800.jpg
I discovered the p5b dlx in 2006, and you enlight it again in 2008 !! great job as always :toast:
Yes, i think the problem can be the new bios for wolfyes on P5K series...in fact yesterday i tried to bench again with this new bios on my 665 fsb E6850 but surprise...i found the fsb wall around 610 Mhz like on 8500...:shakes: this can suggest that somethings on new bios limit our clock. You know the best bios on p5k for exaple was 0414...with another bios i reached only 5500Mhz vs 5740Mhz reached using 0414 (E6850)...maybe the situation is similar.
I tried to play with pll but nothing happened...tried from 1.5 to 1.8.
It's blocked on fsb :shrug:
Do you think we can hope in a new p5k bios like old 0414?:rolleyes:
Good going fellas. :)
GTL Ref V is needed to stabilize higher FSB/Mem straps, to remain within the narrowed margins. More important with DDR3 FSB:RAM ratios.
ASUS is know traditionally to decrease NB performance and increase it's latencies to allow higher FSB. So when benching, keep this in mind. ;)
Thank you, misteroadster-san. :)
I am glad to still take an active part P5B Deluxe. :D
I think we can hope it. :yepp:
Even if it is useless, some good method will be found. :D :up:
Thank you for your opinion and advice, KTE-san. :)
Actually there are some P5K and P35 mobo that can work by high FSB with Wolfdale. :confused:
I want to know what difference are there from my P5K..... :D
:shocked: Insane FSB and CPU clock ..... im wordless..
New bios for p5k...1005,tried now. Solved my cold boot problems,now start without problems at -130°. But for other issue :shakes:
Good update NewBeetle-san...
Watching your progress and 2d damage...
Keep pushing it.
nice update
Cant wait to read more about your progress Newbeetle-san
Amazing FSB This will be a very exclusive club !!
Thank you, Oliver-san. :)
Now I'm a 3D Bencher. :p:
Next week I'll be back the Pi world. :D
Thank you , THC-san. :)
I want to get good results of 8M and 32M next runs. :D
Thank you so much, diezel-san. :)
Hi, my friend KTE-san. :)
I want also to hear your idea.
I will wait until you have time. ;)
DEWA DEWA
NewBeetle
next week i attempt to join te club (vcore modded commando E8500 ln2)
nice result
Thank you, Felipe-san. :)
Finally i got it. :D
hexus_pifast WR : 15.86s @5928.4MHz (FSB624.0MHz x 9.5)
http://homepage2.nifty.com/NewBeetle...fast_15s86.png
Setup
CPU:Core2 Duo E8500#2 Q745A703
M/B:ASUS P5B Deluxe WiFi Rev.1.04 #6 vmod / BIOS:1223
M/B Bed:V-TEC ARC Bed Rev.3.3
CPU cooling:MaxxNeo + LN2 / Temp:-155C
NB cooling:Tara-chan 1st + LN2 / Temp:-45C
SB cooling:stock
Mem:Team PC2-8500 C4 #2 1GB x2
VGA:MSI NX7900GTO 512MB PCI-EX
HDD:Maxtor 6Y080P0 (IDE)
PSU:SilverStone OP1200
OS:Windows Server 2003
CPU Multiplier:x9.5
FSB:550MHz @boot
CPU/Memory:1:1
PCIExpress:100MHz
PCI Clock:33.33Mhz
Vcore:1.952V(CPU-Z)
Vdimm:2.60V(Actual)
FSB Termination Voltage:AUTO
NBVcore:1.70V(Actual)
SBVcore:AUTO
ICH Chipset Voltage:AUTO
"JP Pmem Strap Tweaks" / Special Thanks, before-san
FED14030h => 06
FED14034h => 12
FED1403Eh => 04
FED1403Fh => 25
FED14040h => 08
DEWA DEWA
NewBeetle
Well done NewBeetle!
I wish i could hear the sound of your P5B while benching pifast at those monster clocks :p:
Nice WR NewBeetle-san. The 965 chipset doesn't stop surprising me. I noticed you had you northbridge cooled to -45C. Did you notice a coldbug if you got too cold? How much did that help your FSB or stability?
