As many of us know, when a result is too spectacular there is the increased risk of having it declared invalid. This has always been a sore point about the quorum system for those of us who like to run heavily-overclocked machines.
Wow, thats a great bench. That is borderline optimized good. Pity they couldnt have done this sooner - when it actually mattered and was relevant.
Oh well, water under the bridge...
-SS
Ok guys here is my problem:
clover3 @ 3.15 benched under 5.10.7 3108/6921. So scale linear:
clover3 @ 3.60 would be about 3552/7909
Now compare that with 3453/10403
It looks like boinc is still inconsistant with the integer benches. So maybe clover3 needs a couple of rebenches in order to get the "new" bench. :D
My C2D is benching at
3309 Whet/7529 Dhry
How does this compare with other E6700's? I'm running at 2261 MHz and 336.1 Mhz Bus with a Rated FSB of 1344.
Well, I have only been doing this a few days, according tot he WCG stats page, everything that has been validated is good, no problems yet with half points or failures.
Just curious but how many running processes to you have in Vista64? How many benches did it take to get that?
Ok. 5.10.8 On XP32... Max bench at 3.7Ghz is
27/06/2007 00:34:54||Benchmark results:
27/06/2007 00:34:54|| Number of CPUs: 1
27/06/2007 00:34:54|| 3495 floating point MIPS (Whetstone) per CPU
27/06/2007 00:34:54|| 7808 integer MIPS (Dhrystone) per CPU
27/06/2007 00:34:55||Resuming computation
27/06/2007 00:35:03||Running CPU benchmarks
27/06/2007 00:35:04||Suspending computation - running CPU benchmarks
27/06/2007 00:35:35||Benchmark results:
27/06/2007 00:35:35|| Number of CPUs: 1
27/06/2007 00:35:35|| 3549 floating point MIPS (Whetstone) per CPU
27/06/2007 00:35:35|| 7844 integer MIPS (Dhrystone) per CPU
27/06/2007 00:35:36||Resuming computation
27/06/2007 00:36:12||Running CPU benchmarks
27/06/2007 00:36:13||Suspending computation - running CPU benchmarks
27/06/2007 00:36:44||Benchmark results:
27/06/2007 00:36:44|| Number of CPUs: 1
27/06/2007 00:36:44|| 3543 floating point MIPS (Whetstone) per CPU
27/06/2007 00:36:44|| 7989 integer MIPS (Dhrystone) per CPU
27/06/2007 00:36:45||Resuming computation
27/06/2007 00:36:49||Running CPU benchmarks
27/06/2007 00:36:50||Suspending computation - running CPU benchmarks
27/06/2007 00:37:21||Benchmark results:
27/06/2007 00:37:21|| Number of CPUs: 1
27/06/2007 00:37:21|| 3554 floating point MIPS (Whetstone) per CPU
27/06/2007 00:37:21|| 7920 integer MIPS (Dhrystone) per CPU
27/06/2007 00:37:22||Resuming computation
27/06/2007 00:37:26||Running CPU benchmarks
27/06/2007 00:37:27||Suspending computation - running CPU benchmarks
27/06/2007 00:37:58||Benchmark results:
I have disbled only a few of the services in vista, honestly not many of them.
I had win explorer, msn, IE7 and newsleecher open when I ran those benches, and I only ran them once, 12 hours or so apart.
I got my first invalid today, have no idea what this means.
Result Log
<core_client_version>5.8.15</core_client_version>
<![CDATA[
<stderr_txt>
Failed to get VersionInfo size: 2
</stderr_txt>
I'm still having issues with my desktop crashing even while its installed as a service.. Whats going on here. I even put the cpu at stock speeds to see if it had something to do with my oc but it still did it.. I'm running 5.10.8 now so lets see if it still does it..:mad:
Yes, my problem exactly.. Although it does keep crunching:D I left mine that way for an hour and watched boincview and it kept crunching..
Theyve pulled 5.10.7 from download so something is pretty borked with it.
-SS
I'm guessing 5.10.8 will be next on the chopping block.
Its not much of an issue to run and crunch without explorer but it still tells me there is an issue somewhere.. Which bothers me.
I haven't had any problems with 5.10.7 installed as single user on my notebook. My main rig is still running 5.8.15 just because I can't upgrade it. The installer flips a tit saying it can't find a file. I check that path and the file is in fact there. Not a big deal though, I need to repartition it soon.
jspace, just copy ALL thie files out of your BOINC folder on an already upgraded machine to the one you can't upgrade with the BOINC service stopped. Then, restart the BOINC service. You are upgraded.
Yes, I know it is a few extra steps to upgrade, but since I plan on wiping the drive and reinstalling windows, I don't see the point. Especially since I'm not really running BOINC projects on there ATM. I had to start running WCG on my laptop because sch.... err... the place where I have most of my crunchers is moving things and they are shutdown. :D
I have to do things like you said alot, my C:\ drive is only 4Gb:( It was a :censored: installing the service pack for it a few months ago. I should be getting my water loop (FINALLY!) soon, that is when I plan to clean/organize/tidy up all my files, cables, and dust. When that happens I will install whatever the latest 64-bit client is and re-commit to WCG.
BOINC 5.10.12 beta is available.
http://boinc.berkeley.edu/download_a...2&type=win_new
Again it's a beta, so use at your own risk.
Thanks Sierra, installed the 64bit version, does not seem to have fixed the odd benchmarks I got though.
7/5/2007 7:49:31 AM||Running CPU benchmarks
7/5/2007 7:49:41 AM||Can't start benchmarks - they're already running
7/5/2007 7:50:02 AM||Benchmark results:
7/5/2007 7:50:02 AM|| Number of CPUs: 2
7/5/2007 7:50:02 AM|| 3408 floating point MIPS (Whetstone) per CPU
7/5/2007 7:50:02 AM|| 10252 integer MIPS (Dhrystone) per CPU
Not sure, but I seem to be helping the quorum quite a bit as I am claiming alot more points that I am getting, only getting about 91-93% of what I claim. Oh well, all are coming across as valid, so that is all I can ask.
Could you please do me a favor and post a screen shot of your daily wcg points along with your clocks and runtime.. I am really curious if your doing better than any other E6600 at the same speed and runtime. Thanks!
