Cool, like to see some scores, real world bench's...:cool:
in the dram setting i have to set mode 3:
DRAM Timing
#1:Auto//Mode3 (try both)
#2:Auto
#3:Fast
#4:Fast
#5:Auto
#6:Auto
#7:Auto
if i set auto-mode1 or mode 2
mi sys is not stable at 500 1\1
someone can explane me whath really means this settings? wich is fast? auto-mode 1 -2 or 3?
I don't think your 100% correct. You must first find out what the stock VID of your chip is first, don't assume that the stock VID for all CPU's are 1.3 or 1.325. My stock VID on my E6600 is 1.265, so If i wanted to have 1.515 Vcore I would do this:
1.265 + 0.250 = 1.515Vcore
I'm not much of a bencher, so I'm not sure if I'm doing this right, but I ran 3DMark 01, 03, 05, 06 with the minimum set of tests required to get a score.
3DMark01: 47278
3DMark03: 30183
3DMark05: 15692
3DMark06: 8569
Overdrive clocks are set to: 675/738 (up from stock 600/700)
hey what do you guys set auto detect pci clock too,
oh and heres the highest fsb i can get right now, may need way more vmch but will try that next time
http://img134.imageshack.us/img134/3...un13422kd6.jpg
Anybody runnin 4x1024 with this board and still getting high clocks???
Anyone having cold boot issues. My settings are stable. Normally a simple restart on the cold boot will allow me to boot no problems ect..
yep, if it hangs on the bios screen jsut do a reset and itll fire right up, i get that all the time and the reset works if the settings are good
[QUOTE=MADMAX22;2152269]hey what do you guys set auto detect pci clock too,
Why does your cpu temp in smartguardian say 206c???
I have auto detect pci to enabled.
can anyone crank up their pci-e clock higher than 105? I had my p5b dlx to 120mhz with no problems to allow a higher video card overclock. with the 965s At 105mhz my 8800gts doesn't overclock as high.
i'm having the same issue... but if i set the :
DRAM Timing
#2:Auto
#3:Fast
#4:Fast
#5:Auto
#6:Auto
#7:Auto
if i set auto-mode1 or mode 2 mi sys is not stable at 500 1\1 (cold bot)
if i set it to 3 there is no problem of cold bot
TO TRANSAM the temp is because its on phase so it goes back from 0c but doesnt recognize negative numbers so it starts from the top and works its way back again from 255c i think it is, so its really at -48c or so
tat and core temp allways read 4c when less then a certain amount, i think thats jsut where they stop at, speed fan usually reads it right
and no i havnt gone above 105, i usually never do much more then 105 personally
E6400, DFI Infinity P965-S bios 4.24, 2x1024 Xtreem Team 1066 5-5-5-15 (2.3-2.4V). Need 1 reset for first boot, CPU Feature disable all. Foto with bios settings and Memtest 1.70 test #5.
And SuperPi 32M finish :clap:
i got my hands on one of those...:D
and my 1st thought was to test my ocz 9200 and see if it makes any major difference form my previous mobo (abit quad GT)
on abit i struggled to hit 600........
but with dfi dark........not only i raised my pi 1m limit on my ram but i was able to run all 3dmarks at 600 5-5-5- with 2,35 vdimm read by ITE
X6800 watercooled by apogee and dual BIX 240
2 x 1024 ocz 9200 flex 2,35 vdimm
dfi p-965 dark
twintech 8600 GTS
lc-power 850w
http://img485.imageshack.us/img485/6...7251100tp2.jpg
http://img485.imageshack.us/img485/6...7251100mn4.jpg
http://img237.imageshack.us/img237/7...7251100ns7.jpg
http://img485.imageshack.us/img485/7...7251100ou4.jpg
http://img106.imageshack.us/img106/7203/pi32610nm5.jpg
http://img237.imageshack.us/img237/1...m630555xl7.jpg
been working on "her" for 10 hours......
i am quite happy so far.......:toast:
steelballzz try 4:5, not 2:3.
4:5 doesnt work very well
#1 Mode3
#2:Auto
#3:normal
#4:normal
#5:Auto
#6:1
#7:2
trfc 60
the rest i dont know it just by memory.....and i am at work away from my rig
but i followed the guide from frecableguy at thetechrepository and his guidelines are great
at home i have a pic with memset open....later i will post it
Is this board similar to the Commando?
