2GB G.Skill 6400HZ
@980MHz 5-4-4-9 vdimm 2.25V
2GB G.Skill 6400HZ
5-4-4? download mbench and memset. check the latency at 5-4-4. Then set to 5-5-5 and recheck latency.
my 24/7 settings:
Brand: Mushkin Xtreme (2x1gig) PC2-6400 (don't know the D9 flavor)
Speed: 900 MHz @ 4-4-3-10
Voltage: 2.25v
OEM Micron D9GKX DDR2 800 @ DDR 972 4-4-4-10 2.2v
4GB OEM Micron D9GMH DDR2-400 @ DDR2-1200 4-4-4-12 2.2v
micron has gkx oem? cool. all i knew was that crucial topped at gmh iirc
Cellshock PC2-8000
@ 1000MHz, 4-4-4-12, 2.15v
hmm kingston 2x1gb 533 cl 4 micron d9 gmh
2.2V DDR2 1127mhz 5-4-4-8 2T
Cellshock PC8000 @ DDR1000 5-5-5-15 1.85V:D
TeamXtreem PC5300 @ 545mhz CL5-5-5-12, 1.88v
http://img48.imageshack.us/img48/214...551219vbc3.jpg
I use mine CellShock PC6400 @ PC 8000 / 1000 Mhz 4-4-4-4 @ 2,2 v
TG PC5300
500 4,4,4,12@2.15v motherboard won't go any higher unfortunetly.
generic micron d9dqw fat body (cheap ones)
472 4-3-2-1 @ 2.39
2.35V 24/7
2x1024MB CellShock DDR800 (D9GMH) + 2x1024MB Crucial Value (D9GMH)
DR800 3-3-3-3 :D
1.9v 24/7
2x1024 Patriot DDR800
437mhz 4-4-4-4
ocz 8800 d9gmh. ran at 2.37v for 3 weeks. they nuked already. rated for 2.4v
3.29v just read my CAS 3 post :P, Actaully 2.41v, on a set of 6400c3 Corsair. Has been running for 4 months with no problems.
Ram: Tram Xtreem pc5300 3-4-4-8
Daily settings are 520mhz 4-4-4-5 @ 2.25v
I just started playing with this great el-chepo memory!!
2.2V and I run out of my mobo stable HTT :p:
Attachment 57119
Any suggestions??
For more go over there:
http://xtremesystems.org/forums/showthread.php?t=138352
Can You give us more info about that?
I Have 2 pairs of 2gb kit CellShock 6400 (gmh) and after 1 month they need more voltage for same Mhz.
Eg I had 2.15v @ 450 4-4-4-12 and now I need 2.3v to be stable...
BUT only with the one dimm.Not both:confused:
I cannot even boot at 533@1.8v...I need to boot only with ''good'' stick set 2.25 eg and boot with both.:mad:
Same to my older 2gb kit...
Its realy too disappointing :(
