fine, actually. I've got some dye in there as well, and it seems to have dimmed the "UV" a tiny bit, but other than that, no issues.
I purposely installed a block that had some algae on it, and that's almost completely gone...
As the dye has seeped into the tubing, it's hard to see if there was any effect on the tubing itself, but i did notice one thing....
my pump(MCP655) is very very quiet now.
:stick:
I'll pull it apart maybe this weekend and post up some pics. That's some longterm testing...:lol2:
If all goes well I'll have a 3,100BTU chiller made that I'd be willing to make a test loop for this stuff to see what happens at low temps, and I have an assortment of metals I can test it with. Aluminium sheet, Stainles steel sheet, Copper shet, Brass and such.
See how Methonol effects it.
I have used this in my loop now for a few months...no hard data as I have no easy methods for measurement of temps
but for the more casual XS user(does that exist)...I like this additve
I have a PA160 with a storm rev2 block, mcw 60..cooling e6600 L629f and x1900xt...my temps seem fine
I have ambient of ~25C, idle at 33C with 1.4v(1.37/1.38v real based on DMM) and Panaflo 120x38mm fan at 7v...my loads with fan at 12v are in the mid 50s with 12hrs plus Prime95 blend
I have gotten no algae..my tubes are "cloudy" but I saw this when I used Zerex with my masterkleer
I see no down side to the product and I beleive as a min. temps are no worse maybe a bit better
