Memset Rules! Definately eternally grateful to FELIX for such an awesome program!!
Nice timings vivi!!
I meet a problem with 3.5 Memset: It doesn't read memory frequency correctly, 100Mhz too high. Is there anything I could do too fix this ? Or do I have to deal with like this ?
CPU-Z 1,45 does read correctly, but 1,46 version shows the same error.
Mobo: X48 Evolution
Ram: Cell Shock 1800 8-7-6-21@1,9vdimm
OS: Vista and XPpro 32.
Would a Register Dump from Cpu-z help ? Thanks
...yes, you can send a register dump at memset@hotmail.fr.
What is the memory ratio in bios? On XP or Vista?
Strange that cpuz 1.45 read it correctly, and not 1.46...
I have an interesting question for you.
I have a dual socket SM X7DWA-N MB w/ 2-E5450 Harpertowns in it.
Memory is Kingston HyperX DDR2-800FBDimms 5-5-5-19
Default is 1.8v to the memory.
Acording to Kingston with 2.0v the memory will do CAS 4-4-4-12
If I can work out a vdimm mod on the board, how to reset the spd to boot at the cas4 settings.
No adjustments in bios available.
The only board that takes these sticks that has vdimm voltage adjustments in the bios is the Skulltrail and maybe the Asus Z7S/
Any thoughts?
If you have no timings adjustement in bios, the only
way will be to change your spd table with a soft like SPDTool, but it's risky...
Here is the ratio shown in both vista32 and xp32, the one chosen in BIOS is readed correctly by cpu-z 1.45 -> 2/3.
http://images4.hiboox.com/images/280...9cf1bc5b43.jpg http://images4.hiboox.com/images/280...e163560fd8.jpg
I send the Dumps asap.
Any new versions ready for testing yet?
http://images4.hiboox.com/images/320...b35dd76300.jpg
I still meet issues on ram frequency readings. It happens only when I set great ram speeds it seems.
MemSet v:3.5.5 beta
-Add support for Intel G35 chipsets.
-Add support for Intel PM45/GM45 (Mobile) chipsets.
-Fix a bug with the Save function on Intel chipsets.
-Improve reading frequency with some Intel CPU.
Some memory test from OCCT released 1-Aug-2008
CUDAMemTestv0.2a
Felix your program is awesome Thanks :up:
Have used it since you began work on it. Just recently bought a new notebook and am trying real hard to find the memory speed but not having much luck here.. take a look at this!
http://img143.imageshack.us/img143/1...betazs3.th.jpg
Felix great work for the community, i hope you continue supporting us along
with future upcoming chipsets and faster ram chips. tweaking our mems this
way, is just awsome. :up:
unfortunately i'm having some issues to stabilize a E8600 at 4.7GHz with DDR3.
can't wait to use it here!
What is your memory frequency?
Could you send a register dump (with cpu-z) at memset@hotmail.fr ...
=> ihjones: could you try this version: memset357beta and tell me the result...
Cool THANKS Felix :clap:
http://img381.imageshack.us/img381/1...set2mu1.th.jpg
The program reads the values correctly for me, but as soon as I change anything and hit Apply, the system simply freezes and I have to hit the Reset switch. Any ideas?
http://img56.imageshack.us/img56/5571/memsetwm3.gif
System:
Asus M2A-MX mobo (690V chipset), Phenom X4 9650, 2x1GB Corsair XMS2, Radeon HD4850 512MB, M-Audio Delta1010LT PCI audio card, Vista SP1.
which chipset does your board have?
=>JimmiG: if you change nothing and click on "Apply" , is the system freeze too?
Could you run this soft, choose "Bus:0 Dev:24 Fct:2" in the second combo,
click on the "pci.txt" button and show the result here or send it at memset@hotmail.fr
Hi everyone, as I'm new on the forum, :)
I know MemSet since I used it on my old pc (mobo IS7, P4 3ghz@3.2) on which I tried to use 3 gb (3 sticks) sdram ...
But today, I woul want to use it on my notebook C90S ASUS. I have 2 gb DDR2, 5.5.5.15.
With Memset I've already got 5.4.4.12, but I can't change CAS (CAS#latency tCL). :(
Does anybody know why ? And how to fix ? :help:
Thanks in advance. :)
Bonjour à tous, je suis nouveau dans ce forum,
Je connais Memset depuis que je l'avais utilisé sur mon acien pc (mobo IS7, P4 3ghz@3.2) sur lequel j'essayais d'utiliser 3 GB de SDRAM, avec une barette différente sur les 3.
Mais aujourd'hui, je l'ai installé sur mon portable ASUS C90S. J'ai 2 Gb DDR2, 5.5.5.15.
J'ai obtenu avec Memset 5.4.4.12, but je ne peux pas modifier CAS (CAS#latency tCL). :(
Qq'un sait-il pourquoi ? Et comment corriger ce défaut ? :help:
Par avance, merci. :)
Es ist nicht möglich, sich #Cas unter Windows auf DDR2 zu verändern. :D
