Try raising the vcore to 1.40v bios first, I'm not convinced its your ram. at 892MHz the ram should be ok.
@ KRich - the PL10 is the lowest you can go on 1:1 divider due to chipset limitation with P45 unfortunately. No way around it.
Looking forward to seeing that Grn.
Hey guys,
I measured today some voltages on this board with an multimeter...
- in different FSB-Rate -> 333MHz, 450MHz, 500MHz
- between manual and auto voltage (BIOS)
http://www.abload.de/thumb/miifxyh.jpg
(description in german; Messgerät = multimeter)
result:
The voltage which is set manual in the BIOS is exact the same which i measured...
But if u set the voltage on auto than the voltage is very high if u use an higher FSB.
Means.. if u use higher FSB u should set the voltage manual.
GaBBa
also which LAN should i disable to avoid IRQ bsod?
What IRQ BSOD problem are you having? I have not experienced that with my system.
IRQ not equal, someone said that i should turn off LAN 1
IRQ not equal usually indicates a driver crash (like display driver for example) but i'm not sure in your case. You could try either one I guess and see if that helps.
Well I managed 555fsb stable with these settings:Quote:
can u give me the bios setting , please :up:
Ai Overclock Tuner: Manual
Ratio CMOS Setting: 8
FSB Frequency: 555
CPU Clock Skew: Auto
NB Clock Skew: Auto
FSB Strap to North Bridge: Auto
DRAM Frequency: DDR2-1112MHz
DRAM CLK Skew on Channel A1: Auto
DRAM CLK Skew on Channel A2: Auto
DRAM CLK Skew on Channel B1: Auto
DRAM CLK Skew on Channel B2: Auto
DRAM Timing Control: Manual
1st Information:
CAS# Latency: 5 DRAM Clocks
DRAM RAS# to CAS# Delay: 5 DRAM Clocks
DRAM RAS# Precharge: 5 DRAM Clocks
DRAM RAS# Activate to Precharge: 15 DRAM Clocks
RAS# to RAS# Delay: Auto
Row Refresh Recycle Time: 55 DRAM Clocks
Write Recovery Time: Auto
Read to Precharge Time: Auto
2nd Information:
Read to Write Delay (S/D): Auto
Write to Read Delay (S): Auto
Write to Read Delay (D): Auto
Read to Read Delay (S): Auto
Read to Read Delay (D): Auto
Write to Write Delay (S): Auto
Write to Write Delay (D): Auto
3rd Information:
Write to PRE Delay: Auto
Read to PRE Delay: Auto
PRE to PRE Delay: Auto
All PRE to ACT Delay: Auto
All PRE to REF Delay: Auto
DRAM Static Read Control: Auto
DRAM Read Training: Auto
MEM. OC Charger: Enabled
Ai Clock Twister: Auto
Ai Transaction Booster: Auto
PCIE Frequency: 100
CPU Voltage: 1.41875
CPU PLL Voltage: 1.61925
FSB Termination Voltage: 1.24575
DRAM Voltage: 1.93250
North Bridge Voltage: 1.28550
South Bridge 1.5 Voltage: Auto
South Bridge 1.1 Voltage: Auto
CPU GTL Reference (0): Auto
CPU GTL Reference (1): +40mv
CPU GTL Reference (2): Auto
CPU GTL Reference (3): +40mv
NB GTL Reference: Auto
DDR2 ChA Reference Voltage: Auto
DDR2 ChB Reference Voltage: Auto
North Bridge DDR Reference: Auto
CPU Configuration:
C1E Support: Disabled
Max CPUID Value Limit: Disabled
Intel Virtualization Tech: Disabled
CPU TM Function: Disabled
Execute Disable Bit: Disabled
Load-Line Calibration: Disabled
CPU Spread Spectrum: Disabled
http://img135.imageshack.us/img135/4...fsbidleku5.jpg
Anybody a Idea ?
Prime always stops (Core 1) at the 768K test after 1 hour and 10 minutes
Does anybody have a template for Q6600?
I want to give it a shot b4 I try my E8400.
Thanks!!
Grnfinger can u post your settings for your Q9550? I am I just got a maximus II upgraded from Maximus X38. My Q9450 ran fine on my X38 board @3600mhz but I know it can do 4000mhz if u put 1.35v into it, problem was at those speeds I couldent run the ram in the speed I wanted on the X38 so I gave that up. But I am a total noob on this board and I dont know what settings I should have for my Q9450 anyone have adivices?
Hi guys, i would like to ask you something! What do you think which is the best bios for this mobo??
I am very keen on buying one and i want to know with which bios i have more performance! :up:
Here is a 450x8 3600MHz setup
Good place to start and you can move up from there
This is 8+ hours prime stable
Extreme Tweaker
Ai Overclock Tuner : Manual
OC From CPU Level Up : AUTO
CPU Ratio Control : Manual
- Ratio CMOS Setting : 8
FSB Frequency : 450
CPU Clock Skew : Normal
North Bridge Clock Skew : Normal
DRAM Frequency: DDR2-1081
Dram Clock Skew CH1 A1 : Advanced 300ps
DRAM Clock Skew CH1 A2 : Advanced 300ps
Dram Clock Skew CH1 B1 : Advanced 300ps
Dram Clock Skew CH1 B2 : Advanced 300ps
CAS# Latency : 5
RAS# to CAS# Delay : 5
RAS# Precharge : 5
RAS# ActivateTime : 15
RAS# to RAS# Delay : 3
Row Refresh Cycle Time : 55
Write Recovery Time : 6
Read to Precharge Time : 3
Read to Write Delay (S/D) : 8
Write to Read Delay (S) : 3
Write to Read Delay (D) : 5
Read to Read Delay (S) : 4
Read to Read Delay (D) : 6
Write to Write Delay (S) : 4
Write to Write Delay (D) : 6
Write to PRE Delay : 14
Read to PRE Delay : 5
PRE to PRE Delay : 1
ALL PRE to ACT Delay : 5
ALL PRE to REF Delay : 5
DRAM Static Read Control: Enabled
Dram Read Training : AUTO
MEM OC Charger : AUTO
Ai Clock Twister : Stronger
Transaction Booster : Manual
Common Performance Level [8]
Pull-In of CHA PH1 Disabled
Pull-In of CHA PH2 Disabled
Pull-In of CHA PH3 Disabled
Pull-In of CHA PH4 Disabled
Pull-In of CHA PH5 Disabled
Pull-In of CHB PH1 Disabled
Pull-In of CHB PH2 Disabled
Pull-In of CHB PH3 Disabled
Pull-In of CHB PH4 Disabled
Pull-In of CHB PH5 Disabled
PCIE Frequency : 101
CPU Voltage : 1.35
CPU PLL Voltage : 1.50
FSBT : 1.33850
DRAM Voltage : 2.12
North Bridge Voltage : 1.39150
South Bridge Voltage 1.5 : 1.5
South Bridge Voltage 1.1 : 1.1
CPU GTL Reference 0 : +20mv
CPU GTL Reference 1 : +10mv
CPU GTL Reference 2 : +10mv
CPU GTL Reference 3 : +20mv
North Bridge GTL Reference : AUTO
North Bridge DDR Reference : AUTO
Load Line Calabration : Enabled
CPU Sread Spectrum : Disabled
