Originally Posted by
adya
ok ive finally got 4x1gb stable at 475fsb/1140mhz /3.8ghz. occt stable for 2hrs.
i had it stable at 500fsb on a 1:1 ratio but it was too hot .it needed way to much juice . but honestly ,i didnt notice a difference between 475 and 500. really , there wouldnt be much difference in performance imo.but theres a difference in the amount of volts needed.
im sure with quads u could easily acheive this with much less volts and more tweaking, but with this c2 it really needs volts i think.
one thing i noticed is that with the same settings and output ,and fine delay set to a certain group of numbers was stable . then later the same settings and output was also stable but with different fine delay figures? ive been taking notes . so its not a mistake, the numbers vary quite abit .id luv to know what the variable is. and how both sets of figures equate stability?
