Sup all.
Got my Q6600 running at 389X9 for an even 3.5GHz, stable.
I'm a bit worried about the vcore I have to use to get it there, probably due to the high VID of 1.3250v.
I tried lower vcore's but it will lock up on the desktop and reboot or give me a BSOD and reboot.
I can get it to 400x9 for a nice 3.6GHz but temps go too high and it fails prime.
I also tried 438x8 for 3.5GHz but having trouble keeping it stable, NB temp goes over 47 and upon booting it fails the OC with either no display init or just hangs at detram.
I have removed the cooling assembly when I received my Maximus (freezer popped right off) I have applied AS5.
My TRUE and Q6600 are lapped with AS5, also using a push/pull configuration.
I would just like some input on my high vcore and my settings if theres anything I might need to change.
Here are my settings and screen shots of temps below.
Extreme Tweaker
Ai Overclock Tuner : Manual
OC From CPU Level Up : AUTO
CPU Ratio Control : Manual
- Ratio CMOS Setting : 9
FSB Frequency : 389
FSB Strap to North Bridge : 400
PCI-E Frequency: 100
DRAM Frequency: DDR2-1037
DRAM Command Rate : 2T
DRAM Timing Control: Manual
CAS# Latency : 5
RAS# to CAS# Delay : 5
RAS# Precharge : 5
RAS# ActivateTime : 15
RAS# to RAS# Delay : 3
Row Refresh Cycle Time : AUTO (52)
Write Recovery Time : 6
Read to Precharge Time : 3
Read to Write Delay (S/D) : 8
Write to Read Delay (S) : 3
Write to Read Delay (D) : 5
Read to Read Delay (S) : 4
Read to Read Delay (D) : 6
Write to Write Delay (S) : 4
Write to Write Delay (D) : 6
DRAM Static Read Control: Enabled
Ai Clock Twister : Light
Transaction Booster : Disabled
CPU Voltage : 1.54375
CPU PLL Voltage : 1.50
North Bridge Voltage : 1.39
DRAM Voltage : 2.08
FSB Termination Voltage : 1.28
South Bridge Voltage : 1.050
CPU GTL Reference : 0.63x
North Bridge GTL Reference : 0.67x
DDR2 Controller REF Voltage : DDR2_REF
SB 1.5V Voltage : 1.50
NB LED Selection : NB Volt
SB LED Selection : SB Volt
CPU LED Selection : CPU VOlt
Voltiminder LED : Enabled
Advanced CPU Configuration
C1E Suppport : Disabled
CPU TM Function : Disabled
Vanderpool Technology : Disabled
Execute Disable Bit : Disabled
Max CPUID Value Limit : Disabled
USB Configuration
USB Functions: Enabled
Legacy USB Support : Enabled
http://img245.imageshack.us/img245/8...3500jz2.th.jpg
