my major targets are done with the 3700+ and 4000+ wr's... i don't know which i should hunt next...
too expensive and too rare are those fx...
damn... these 22sec are hardcore... haven't cracked them yet...
edit: the non-fx wr is mine!!!! with less mhz than stephen had :D
Show us your results ;)
The Opteron 170 wr is mine @ my SLI-D :banana: Many more mhz than the old...
hehe congratz... i'm not finished yet... the cpu goes better and better :D
attention stunned there is a new cpu-z version 1.42!!
he has hundred of cpus!!! :D
@ bruce
Here is the result:
new WR Opteron 170: 3663.24 Mhz @ 1.776 v
The heat spreader was away from that cpu so I had to take another one above it because of the cold bug.
The validation was made with +23c....have to boot with 10x300 then push with Prime95 to get temps around +40c and then I could clock the MHz higher during fallen temps.
Cold Bug sounds like this:
245 mHz @ -30c
267 mHz @ -22c
283 mHz @ -16c
305 mHz @ -5c
316 mHz @ 0c
342 mHz @ 8c
348 mHz @ 10c
I validated with CPU-Z 1.41 because I forgot to use CPU-Z 1.42....I had luck my validation was upload. ;)
I tried this all on my SLI-D, next time I will use the Expert Venus.
non-fx wr... and again S.I.H. this time => Stephen Is History :D less mhz, faster time.. :up:
http://bastel-gianni.ch/overclocking/superpi_21.875.jpg
That is really amazing....socket 939 will ever live ;)
@stunned_guy: that cb might explain my problems, the coldest core was always~below +5c. The warm one was @ 20 though :p (need to remove the IHS I guess, just to get even temps... then chilled water is next I guess:D dice on rad :p: ) I'll see if I can break your record, but not sure when I'll go for it. I have so many otehr chips to test you know, and this one was a big PITA the last time:D
@gianni nice spi time:clap: almost 2 sec faster than my personal best:D But then I mostly go for cpuz WR's before I try to run my chips @ laod @ 1.85v+;) Don't want to kill them...
amazing result, like always gianni :toast:
looks like i'm mr. s939 superpi :D
http://www.hwbot.org//listResults.do...uSubFamilyId=5
no non-fx 32M wr this weekend... my cpu & ram wouldn't work correctly together anymore.... 1.5sec to the 32M score of stephen... with 3705mhz. :(
hehe i hope also :)
Bruce, do you want to join the club of the san diego bros ? :D
By the way my Opteron is without heat spreader...
hehe what is the 2do list for joining the sandiego bros?
cracking a sandiego wr [check]
being adicted to s939 [check]
what else? :D
lol, crazy dudes. :D
as already said, next week i get my opteron 148.
hope it's a good one. :D
